Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 04-01-2003, 22:32
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
3dmax - setting a display option that I can't find
I recently reinstalled 3dmax. I set the settings to what I like, just theres this one setting that I can't find and is bugging me.
When I draw, say a rectangle, I like to turn on Edged Faces. However, for any face, the line that divides the face into triangles is shown. This line gets annoying after a while, especially when you need to have many small faces close together. I can't find the option that turns this line off... if anyone knows, it would be appreciated.
Screenshot of a rectangle. The line that divides the faces into triangles is what I want to get rid of.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 05-01-2003, 00:02
Skanker's Avatar
Skanker Skanker is offline
#0498 (R.P.M)
Skanker is an unknown quantity at this point
Send a message via ICQ to Skanker
I have had this problem as well. you can sort of fix it by changing your 3d Graphics Processor option to use OpenGL (or vice versa--can't remember). It really doesn't FIX anything, but GL sort of works differently.
HOWEVER if your GPU does not support GL, then you are stuck with Direct3D. In direct3D, a face can only have 3 sides. hence, in a rectangle, the one side of the rectangle has two faces-two triangles.
Faces MUST HAVE three sides. that's the only way our computers can make them exist.
I hope that helps. Sorry if it doesn't. I can be kind of incoherent sometimes.
if you need anything else, feel free to e-mail me at Skanker@skateboard.com.
-Sean
-Sean Rice
Cactus Robotics Club Alumni
Unread 05-01-2003, 00:12
Crusty Mentor
FRC #0097
hmmm, I'm almost positive there's an option to turn it off - I seem to remember being extremely happy the first time I turned that off. I just can't find it.
As for my graphics setting, I managed to hack my geforce256 to a quadro, so I have overclocked openGL - it's fast, and I'm not switching, so there has to be another way
Dan L
Team 97 Mentor
Unread 05-01-2003, 11:06
Devil's Kid's Avatar
Devil's Kid Devil's Kid is offline
#0912 (IRON Lyons)
Devil's Kid is an unknown quantity at this point
I found one option to cause your problem.
Customize > Preferences > Viewport tab > Click on Configure Driver > uncheck option "Display wireframe objects using triangle strips"
Unread 05-01-2003, 12:11
Crusty Mentor
FRC #0097
Yep, thats it. Thanks a lot!
Dan L
Team 97 Mentor
Unread 05-01-2003, 12:42
#0912 (IRON Lyons)
You're welcome.
