Go to Post Once again, my schooling is interfering with my education. - Caleb Fulton [more]
Unread 05-01-2003, 04:40
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
traction questions
M17: robot wheels, tracks, and other parts intended to provide traction on the playing field ("traction devices") may be purchased or fabricated. in no case, will traction devices that damage the carpet or other playing surfaces be permitted. traction devices may not have surface features such as metal or hard plastic studs, cleats, or other attachments. the other surface of off-the-shelf wheels may be modified by removing tread material only. in no case may a traction device protrued beyond the bottom surface of the Ramp mesh. gaining traciton by using adhesives or velcro-like fasteners material is not allowed.
ok... so i've got a few questions:
1. if you have a foam thingy on the bottom of your wheels, and the weight of the robot presses it into the mesh so part of it protrudes through, is that in violation of the rules?
2. i saw a robot last year that used a belt with metal upside-down 'U'-shaped things to grab onto the carpet... that isn't allowed this year, right?
3. our mentor used some polyurethane foam stuff with some traction pattern cut out of it attached to their wheels last year. is that not allowed this year? it says that the outer surface of off-the-shelf wheels may be modified by removing tread material only.
We were the first seeded first-year team at a first-year FIRST regional.
Unread 05-01-2003, 08:59
Kit Gerhart's Avatar
Kit Gerhart Kit Gerhart is offline
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Rookie Year: 1996
Kit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond repute
Send a message via AIM to Kit Gerhart
Re: traction questions
I suspect there will be a clarification on this one at some point, but I can envision part of robot inspection including placing your robot on mesh like that on the field and a straight edge run under the wheels or tracks of the robot to check for protrusion. This, of course, is just a guess.
Team 45, TechnoKats, 1996-2002
Team 1062, The Storm, 2003
Team 233, "The Pink Team," 2004-present
The views I express here are mine, and mine alone, not those of my team, FIRST, or my previous teams.
Unread 05-01-2003, 17:58
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Until further clarification, yes, it is in violation of the rules. If objects are put through the mesh for the purpose of grabbing, the holes could get deformed.
However, this rule is a bit vague, because it doesn't define the maximum extent of the pertrusion. Any circular wheel will pertrude into the opening of the mesh, but only a little bit. My best guess is that most traction material will be fine, they just don't want people sticking a pneumatic rod through the mesh opening to hold their robot's position.
Correct. Carpet-metal interatction is prohibited by the rules. This inclides the ever popular chain-cleat treads.
There's no reason why you cannot use the polyurethane, but you will have to manufacture your own wheels from stock, and then adhere the material to them.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
Q&A Traction Question answer Cory Technical Discussion 4 09-01-2003 06:37
New member, new team, questions. Frank(Aflak) General Forum 21 14-12-2002 06:59
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
