OCCRA
Go to Post The toughest regional is always the one you are competing in! - AcesPease [more]
Unread 05-18-2017, 05:55 PM
kelef's Avatar
kelef kelef is offline
FRC #3695 (Foximus Prime)
Team Role: Leadership
Rookie Year: 2016
kelef is a name known to allkelef is a name known to allkelef is a name known to allkelef is a name known to allkelef is a name known to allkelef is a name known to all
3d printers
Hello! I am in the market for a 3d printer and I'd like you hear what others would recommend. I'd like something not too expensive (under 1000) and I don't care too much about the resolution, but of course I'd take something with a good one. I'm looking to use it for personal messing around with and some robot pieces, of course.
Unread 05-18-2017, 06:06 PM
FrisbeeFunTime's Avatar
FrisbeeFunTime FrisbeeFunTime is offline
AKA: Erik Yngstrom
FRC #1768
Team Role: Mechanical
Rookie Year: 2015
FrisbeeFunTime will become famous soon enoughFrisbeeFunTime will become famous soon enough
Re: 3d printers
I've had good luck with the Printrbot simple metal with a heated bed on it. 6x6x6in build volume with fairly good accuracy.
Unread 05-18-2017, 06:22 PM
XtremeFate XtremeFate is offline
FRC #4505
XtremeFate is a splendid one to beholdXtremeFate is a splendid one to beholdXtremeFate is a splendid one to beholdXtremeFate is a splendid one to beholdXtremeFate is a splendid one to beholdXtremeFate is a splendid one to behold
Re: 3d printers
The Prusa i3 MK2 by Josef Prusa is by far your best option. His printers are incredible quality, he's very attentive to customer questions, and by listening to user feedback the printer is getting better every day (multi-color upgrade kit coming soon)!
Unread 05-18-2017, 06:25 PM
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz will become famous soon enoughtroy_dietz will become famous soon enough
Re: 3d printers
The best value in your price range is easily the Prusa i3 Mk2, pretty much hands down.
The Printrbot Simple leaves some to be desired, (particularly in the movement system) but we've had great success with it over the past season and printrbot donated the machine (along with three others) to us. If you have the student resources to write Brook a sponsorship request letter, I highly recommend it. (PM for details)
If you're willing to do a few upgrades, the Monoprice Maker select is $320 and can rival the Mk2.
Edit: that's a lie, it's now on sale for $300. https://www.monoprice.com/product?p_id=13860
I'd recommend having more than one printer available to you, especially if they are different sizes. Splitting up parts and gluing them together in a small printer is a pain, but the issue goes both ways. Printing small rollers on a 10x10 bed is a waste as the increased mass will require you to print slower. (and you'll have increased artifacting in more detailed prints)
Unread 05-18-2017, 06:28 PM
Brian M's Avatar
Brian M Brian M is offline
Design Lead
FRC #1360 (Orbit Robotics)
Team Role: CAD
Rookie Year: 2012
Brian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant futureBrian M has a brilliant future
Re: 3d printers
Another vouch for the Prusa i3 MKII. I have the Prusa i3 Original and its the best thing ive ever purchased. Ive heard only good things about the MKII version which is 100$ more but has a 31% larger build plate, better heated bed, PEI build surface (No painters tape needed ever), and auto bed leveling.
2016 - Rah Cha Cha Ruckus Winners
2017 - Industrial Design (Durham), Entrepreneurship (McMaster), Quality Award (Ontario DCMPS)
Unread 05-18-2017, 07:01 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: 3d printers
From personal experience, I can HIGHLY recommend the Robo3d R1+ for the "under $1000" category. It has a huge build volume and works very consistently and is fairly low-maintainance. They also have a few newer models coming out if you want a bit more capability though they are a bit more expensive. All of the Robo3D printers also ship pre-assembled so you don't have to worry about the hassle of assembling it or having to calibrate anything.
I just finished a 52-hour part on my R1+, running it at ~85mm/sec, and the part came out great (normally I would run it at ~50mm/sec, though the machine can allegedly work up to 100mm/sec or faster)!
The R1+ features:
  • A heated glass build platform
  • 8"x9"x10" build space (though in practice I've found it's actually a bit larger)
  • Layer resolutions from .1mm-.3mm
  • Works with virtually any kind of filament you can get including polycarbonate (Ninjaflex requires a slight modification to not jam)
  • Automatic "mesh" bed leveling
  • Includes slicer software, but can use 3rd Party software as well
  • Printing from SD card or USB (can also be controlled wirelessly using an Arduino with Octoprint)
  • Ships Pre-assembled
The printer also ships with a stick of Elmers washable school glue to use as a bed adhesive, which has worked better than any other adhesion method I've tried on ANY printer (needless to say, I bought more).
I do have to add a small disclaimer that when I got mine initially it shipped with a bad stepper driver that caused some issues, but I returned that unit for a replacement (buy from a store, not direct, if you want to be able to do this, Robo3D does not offer direct returns, just warranty support) and I haven't had any problems with it or had to do any maintenance since taking it out of the box almost a year ago.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 05-18-2017, 07:24 PM
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: 3d printers
One more vote, I love my Prusa, can't wait for the multicolor upgrade.
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
Unread 05-18-2017, 07:28 PM
Lexeo's Avatar
Lexeo Lexeo is offline
AKA: Alex Henry
FRC #4272 (Maverick Boiler Robotics)
Team Role: Coach
Rookie Year: 2014
Lexeo is an unknown quantity at this point
Re: 3d printers
I would agree with the Prusa I3. I built my own about 4 years ago, and it is still a very capable printer. I would also encourage that if you go this route, make sure go you get it from a reputable source. The Prusa I3 has been around for a while, and there are cheep knock-offs. I would also recommend getting the E3d hotend, as it is very well made. Used their V3 on my printer, and currently using the V6 Volcano on a project at work. Both are fantastic. Josef Prusa (the guy who designed the Prusa I3) sells them from his website http://www.prusa3d.com/prusa-i3-kit with the E3D head installed. He also offers a Kit if you wanted to save some money and learn how to put it together yourself.
I have also heard the Prinr Bots are good quality printers, but have not personally used one.
Another Fantastic printer based off of the Prusa I3 is the LulzBot mini. It is a bit over your budget at $1250, it is an extremely high quality printer with great support also. https://www.lulzbot.com/store/printers/lulzbot-mini.
Unread 05-18-2017, 07:44 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: 3d printers
Prusa i3 Mk2.
Right now, there is no other printer than can compete with the quality and value you get for under $1000.
"It's taking longer than expected, which was to be expected."
Unread 05-18-2017, 08:06 PM
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
Rookie Year: 2007
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
Re: 3d printers
+1 for the Prusa i3. Have heard awesome things about them at that price point. If you pick one off eBay, make sure it's a metal frame unit.
Also have heard good things about the Seemecnc Rostock Max V3 kit, if you don't mind a delta printer.
Check out our engineering program!
304 (student) ->304 (mentor) -> 3929 (mentor/temp lead) -> 4454 (assistant head honcho/head honcho)
Jack of all trades, master of about 2. Interested in mentoring in Philadelphia? PM me!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 05-18-2017, 10:32 PM
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: 3d printers
If your team thinks that the purpose of FIRST is to inspire future engineers, then designing, cading and building your own 3d printer can be a wonderful project. This is exactly what 1640 did last summer. The printer really got a work out during build season. And there is always the pride of " we built this". We based it on Openbuilds materials and inspiration.
http://openbuilds.org/
Unread 05-18-2017, 10:53 PM
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: 3d printers
Our team purchased two Flashforge Creator Pro's this season and they have been running constantly with very little issues.
We are looking at purchasing a few more for our Middle School as they are robust enough to run in a HS drafting lab as well as through an entire season of FRC with great success.
Go Minnesota in 2018!
"Innovation cannot happen in isolation"
Unread 05-18-2017, 11:07 PM
EveryLittleBit's Avatar
EveryLittleBit EveryLittleBit is offline
AKA: Kevin
FRC #2702 (Rebels)
Rookie Year: 2016
EveryLittleBit is on a distinguished road
Re: 3d printers
<brag>
On our robot this year, we had over 300 3D Printed parts. So, you could say we know a bit.
</brag>
First off, if you want a solid, no hassle printer, the MakerBot Replicator+ is the best printer for you. I've seen these print complex pieces in any condition, we even flipped one on its side during a print and it was fine. In the hundreds of hours our mentors rep+ was run, we only had 1 jam, and because of the MakerBots easy magnetically mounted extruder, it was a piece of cake to fix. Finally, the rep+'s flexible build plate is downright magic, it sticks when it prints, but the parts just glide off when you're done.
If you want to tinker, we've had good luck with the FLSUN Delta at only $250, it's a steal, but like most other cheap 3D printers, you'll have to assemble it yourself, and the print quality is lower. We had a bit of trouble leveling the bed at competition, as it was on a rolling bench, and we have made some firmware and hardware mods so it runs better. If you go with the FLSUN, contact me as I'd be happy to help
Tldr. If you want consistent preformance, go with MakerBot, but if you like to live life on the edge, the FLSUN is a solid budget printer.
Unread 05-18-2017, 11:33 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: 3d printers
From the other responses in this thread, I would lean towards the Prusa mainly for the cost standpoint as an easy way to get into printing. Regardless of the printer you use, it will take some time to dial in the settings needed to get the tolerances right on the parts you make.
We used our 5th gen Replicator, Z18 Replicator, and Replicator+ extensively during the season. I wouldn't exactly say they are completely hassle free, but we get the parts made that we need. Lots of parts of our robot would not have been completed without our printers. The entire powertrain for both of our turrets and ball feeding mechanisms were printed.
Cool video from Makerbot: https://www.youtube.com/watch?v=bsKmEQEanHQ
  #15   Spotlight this post!
Unread 05-18-2017, 11:46 PM
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 1999
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Re: 3d printers
I built a Rostock Max V3 last December and after some dialing in, I love this printer. The buid volume is HUGE, way bigger than anything I'll ever need to do for the robot, but the heated bed has made for some really nice prints without any fuss. So far I have only printed in PLA/PHA (plenty of durability for robot season - parts have held up equally as well as our ABS parts printed on a 1200ES Dimension) but the printer is capable of ABS, Polycarbonate, Nylon, and flexible filaments too so you have lots of versatility with one machine. The speed of the delta setup is impressive and fun to watch too.
The kit version is under $1000 and I learned all the ins and outs of the printer by buiding it and saved money over the pre-built kit. I did blow a few fuses along the way though! The community for the printer and customization possibilities were a big seeling point for me too.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
