OCCRA
Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 05-19-2017, 01:00 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
CSA Horror Stories
I've seen a thread for inspector horror stories, but not one for CSAs. I'm looking for either the weirdest things you've found that passed inspection* or the weirdest wiring/coding techniques. Basically, what have you found that's made you stop and say "whaaaaaat".
* Nothing against inspectors. I know they are all trying their hardest, but no one is perfect.
I'll start this off with the weirdest thing I've seen, this illegal radio modification (on a robot that passed inspection).
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 05-19-2017, 01:08 PM
frcguy's Avatar
frcguy frcguy is offline
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Student
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: CSA Horror Stories
Last offseason I had a team that would unplug their driver station any time their radio rebooted. Super frustrating to see them lose coms, then unplug their DS, then see the radio come back up on the field monitor and then them not able or willing to plug it back in and keep playing.
I had another team that as we were troubleshooting electrical issues and tracing wires we came across literal bugs, inside their robot, crawling on the pneumatic tubing.
These are just a few I've seen in my relatively short career as a FTAA/CSA. Can't wait to see some crazier stuff as I start doing more events!
Team 5940: 2015-
Volunteer: FTAA (2016-present)
2 years, over 4000 miles covered. Check out where I've been and where I'm going!
Unread 05-19-2017, 04:15 PM
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
I have so many of these.
2017:
A team put nylon washers below the ring terminal on the 6ga side of the PDP. The screw wasn't even tight, the cover was holding it down. The washers were filed down to fit in the PDP's groves.
I saw a CAN bus terminated in the 12v 2A VRM.
A team tried to use an 85A main breaker.
I met a team back at their pit since they were bypassed in a match. FMS saw their radio but not their rio, and the rio had link lights and chatter on the ethernet port. Powered up in their pit and replicated the problem (how rare!). Couldn't make any headway through the ethernet port, although the rio MAC showed up in the laptop's ARP table. All in parallel we started imaging another rio and getting the JRE on it since I wasn't sure if we could get this rio to work. We plugged into the USB port and we got comms etc. I had 1 laptop plug into the USB port, and another plug into the ethernet port. When we would load 172.22.11.2 and go to network settings the ethernet device just wasn't there. SSH'd in from the USB and did a dmesg|tail. Saw a bunch of errors where the ethernet driver was failing to load. Opened it up to check for swarf, and found none. I called up HQ, relayed this info, and they replied "Yup they need to send that back to NI."
2016:
This team had a programming issue for a few events. Sometimes their code would just not run. It would say its connected, but no joysticks or any motor output would work. Sometimes only 1 stick would work. Early in the season we did some change that improved it, but sometimes the problem would still crop up. At the event before district championship, I was looking at their code, and Brad Miller stopped by. Neither of us found the smoking gun, but we knew it was the code. A default codebase worked fine. After the event, I took a copy of their code and ran it on FRCSIM. I knew I'd see them at Lehigh and it was bothering me that I couldn't solve it. After running like 500 simulations I found out that they were re initializing the HAL. It turned out that they had a class inherit Simplerobot (or one of hte other robot bases). They had multiple instances of this class, and it would be a race condition to see which one actually took the HAL. They were ecstatic when I told them at Lehigh I found the root cause.
2015:
A team was having some issue after their robot ran for some amount of time. I forget if it would hang, watchdog, or throw an out of memory error. It turned out they implemented command based where pressing any button would spawn a new thread. When the command completed they did not remove the thread, so eventually the rio had tens of thousands of zombie threads.
A team said their battery voltage drops tremendously when driving straight while on blocks. I figured it would be a mechanical bind. Sure enough, they drove forward and I heard the clicking of the 40A breakers tripping. In their gearboxes, the motors were fighting each other.
I had a team casually ask me how to get a rio out of safe mode. I laughed and headed over to their robot. Required a complete reimage. While in queue. Oh and they were java so they needed the JRE.
2014:
A team asked for my help since their robot wasn't driving straight. Seems pretty innocuous, plenty of possibilities. They had a 2 cim gearbox for each side of their drivetrain. One cim had the positive lead pull out of the crimp so it were just dangling. UNFORTUNATELY when the robot was driving, the lead would rub against the cRio. Since the motor was being driven it was producing voltage. End result was arc marks on the cRio. It still worked flawlessly.
I found it hilarious that the loan only stickers covered the PCM status lights.
A team had multiple radio drop outs, but each drop out was under a second. Couldn't find anything wrong with their robot, so on their next match I ran a passive packet sniffer to observe their radio. There was something like 40% retransmitted packets and the link rate was low. I think the internal antenna was damaged but I'll never know. We swapped the radio and it worked fine.
2013:
I was called to the field since a robot after the match ended, was still driving while climbed. It turned out there was metal swarf shorting out the signal pin on the victor's PWN pins. I think this was somehow making it drive. After vacuuming it out, it worked properly.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming and Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 05-19-2017, 06:43 PM
Omer Huly's Avatar
Omer Huly Omer Huly is offline
FRC #1690 (Orbit)
Rookie Year: 2013
Omer Huly is on a distinguished road
A team had communication problems on field and while helping them I noticed they swapped the roboRIO and vrm output terminals on the pdp (leaving the roboRIO with a 20A fuse and the vrm with 10A).
Another team which works with labVIEW, written a new autonomous routine between their first and second event. They had their robot die for autonomous period every time they tried it on the field. In their pit they were running the code on the computer in debug mode, but the problem occurred only when the code was deployed to the roboRIO. It turned out that the new autonomous VI was never made it to the final build which was deployed to the roboRIO, so that made the autonomous routine crash every time and the code had to be restarted while leaving the robot dead for autonomous period.
Unread 05-21-2017, 08:43 PM
arichman1257's Avatar
arichman1257 arichman1257 is offline
College Student
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
Rookie Year: 2014
arichman1257 has a spectacular aura aboutarichman1257 has a spectacular aura aboutarichman1257 has a spectacular aura about
These were all this year
Event A
Earlier in the season one of the FTAs told me that they saw that there was a power fault* on this teams roboRIO. I don't know if he saw it on that app the FTAs have* or if he just saw it with his eyes but that's not the point. So I go back to this teams pit and I'm looking for the cause and it turns out that they were intentionally shorting the power and ground of a DIO pin every match as an autonomous selection jumper.
Event B
I was not a CSA at this event because I was my team's drive coach this season. But I have a tendency to help out other teams with CS stuff anyway. There was this one team that was having some electrical issues and one of the first things we noticed was that they tried to use 10-24 bolts in the 5mm inserts for the PDP power. The threads were completely ruined so neither a 5mm or 10-24 bolt would thread in properly and it was very loose. The next thing that happened was they told me that they had some component arcing to the frame. I was incredulous at first but then they showed me video of it happening.
Event C
A team was using ferrules with a ferrule crimper that did not make them square. It just flattened them.
At our shop
Some CS newbies were wiring up a chassis for practice. They were using Victor 888s because they were lying around and forgot to plug in one of the fan wires. In their defense, it was only a small fire, no one got hurt, it went out when they killed the power, and because of the previous things it was kinda funny.
*For the non-CS people, a power fault on the roboRIO is when there is a short circuit on some of the pins of the rio it self or a plugged in peripheral device. Indicated by a red power light on the rio.
**I don't know too much about whats on that app but I'm certainly curious to learn
Control System Advisor
2017: MAR Westtown District Event (PAWCH), North Super Regional (CMPMO)
1257: Parallel Universe
Student (2014-17): Vice President (2017), Control Systems Captain (2016-17), Drive Coach (2017), Operator (2015-16), Poofy Hair (Always)
Mentor (2017-??): idk prolly somethun eventually
Unread 05-21-2017, 09:13 PM
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Originally Posted by arichman1257 View Post
Event C
Interestingly, I would've been surprised to see square crimped ferrules before having read your post and a quick google search. The only ferrules I have ever seen and worked with have been crimped flat.
Do you think one or the other is preferable? The only place I have seen an issue with flattened ferrule connectors is where the power wires come into the RoboRIO, where I've found bare stranded wire to be superior. Would a square crimped ferrule perform better in this application? Everywhere else on the robot I have loved flat crimped ferrule connectors as compared to bare wire.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 05-21-2017, 09:31 PM
College Student
AKA: Alan Richman
Rookie Year: 2014
The Weidmuller connectors need one of two things to be able to work effectively. A wire with a uniform contact surface (ferrules) or a wire that can be compressed (no ferrules). I have never personally seen ferrules that were crimped flat that were uniform. Also, if they are flat then you have to make sure that your're not putting them in the Weidmuller or screw terminal on an angle. When they're square the flat faces will be forced to be parallel to the contact surface inside the connector by the compression force. But the biggest problem I have with flat ferrule connections is that they don't really fit inside of the terminals.
Beyond that, the guy who I talked to from Automation Direct at champs said the following: "Make sure that your ferrules are crimped square" and "No Weidmuller in industry is used without a ferrule"
Unread 05-22-2017, 09:57 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
...Beyond that, the guy who I talked to from Automation Direct at champs said the following: "Make sure that your ferrules are crimped square" and "No Weidmuller in industry is used without a ferrule"
You need to look at what to terminal is listed for. Most of the spring contact terminals like the ones on the VRM are listed for stranded and solid wire with or without ferules. While ferules are good practice, a really high percentage (most?) of industrial field connections are made without them. If you used ferrules they need to be properly crimped with the ferrule sized for the wire. That really is more important than the final shape of the crimp. Bottom line: Have ferrules sized for the wire and use a decent crimper sized for the ferrule. Hint ferrule crimpers use different dies than terminal/connectors.
If you don't know what you should hook up then you should read a data sheet
Unread 05-22-2017, 10:35 AM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
On a previous team, I used This ferrule set.
Worked great.
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 05-23-2017, 10:00 AM
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
Team Role: Coach
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
At our shop...it was only a small fire...
If I used those words in any sentence with my department head he would be pulling out his nitroglycerin and eating the entire bottle.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 05-23-2017, 10:10 AM
AriMB's Avatar
FRC #5987 (Galaxia)
Rookie Year: 2012
Better keep that nitroglycerin away from that fire
I'll also open this up to FTAs and FTAAs if you've seen some crazy stuff I'd love to hear about it.
Unread 05-23-2017, 11:29 AM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
I once had a small blow back when liquid propane puddled in the fire box of our propane/air mixer. My maintenance supervisor didn't understand the fire would go out when the propane burned off, and sort of freaked. He made made more mess with the fire extinguisher than the propane did. He got to clean it up. It is all relative.
Unread 05-23-2017, 11:47 AM
piersklein's Avatar
piersklein piersklein is offline
FRC #0320 (Pyongyang Academy of Denim)
Rookie Year: 2014
piersklein is a name known to allpiersklein is a name known to allpiersklein is a name known to allpiersklein is a name known to allpiersklein is a name known to allpiersklein is a name known to all
A top tier team attempted to solder their radio wires into the VRM.
A team spent the weekend frustrated by motor issues... because they never terminated their CAN.
10 events/8 elims/2 wins
I used to know what I was doing. But then I went on CD and they sorted me out.
Unread 05-23-2017, 12:14 PM
EmileH's Avatar
EmileH EmileH is offline
Passion breeds passion.
AKA: Emile Hamwey
FRC #1058 (PVC Pirates)
Team Role: Student
Rookie Year: 2011
EmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond repute
I think I know who this was directed at
FRC 1058 - 2016-present
FRC 3467 - 2013-2015
Check out some of 1058's Recaps here.
Thanks to all our alliance partners this season!
125 | 238 | 5687 | 4908 | 58 | 3930 | 6328 | 177 | 67 | 2137 | 1640 | 2084 | 5556 | 1519 | 6328 | 5687 | 58 | 319 | 133 | 885 | 4042 | 319 | 2876
  #15   Spotlight this post!
Unread 05-23-2017, 12:58 PM
frcguy's Avatar
Team Role: Student
Rookie Year: 2012
PLEASE tell me someone took photos of the first one.
Team 5940: 2015-
