Go to Post You are beautiful. - Joe Johnson [more]
Unread 05-01-2003, 19:42
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Rookie Year: 2000
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Joystick Worries
I have just discovered a rule that I beleive to be new. In section 4.2 of the robot manual, rule C1, it says that, among other things, a joystick "may not be tampered with, modified, or adjusted in any way." It goes on to say that "Tampering includes drilling, cutting, machining, gluing, rewiring, etc."
This disturbs me because in the past my team and I have always drilled holes in the bottom of the joystick to mount it, we have occasionally rewired them so that the digital switches are outside of the joystick, and we have always epoxied the calibration knobs in place to avoid them being moved and messing up our programming. Can someone "tell me it ain't so?" Thanks.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
