Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 05-01-2003, 21:22
Antonio Antonio is offline
Antonio is an unknown quantity at this point
pressure switch
where should we put our pressure switches for it to turn the compressor on and off?
it seems like it is attached on the pressure tanks in the pneumatics manual, but how is it going to be able to turn the compressor on and off from there? or does it matter where it is placed?
Unread 05-01-2003, 21:29
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
The pressure switch does not turn off the compressor by itself, it merely lets the software know when the tanks are full so that the SOFTWARE can turn off the pump.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 05-01-2003, 22:18
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
rbayer is correct. DO NOT connect the pressure switch in series (directly to) the compressor! You will break your pressure switch. Instead, connect the switch to the Digital Inputs on the Robot Controller as per page 13 of "The Robot" section of the manual. The pressure switch can be located physically anywhere before the 60 PSI regulator. Most teams put it on their reservoir (air tank).
Unread 05-01-2003, 23:28
okay thanks a lot
Unread 29-01-2003, 09:20
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
we have our pressure switch connected directly through a relay going to the pump.. the pressure switch cuts power to the relay, the relay cuts power to the pump.. only problem is that it shuts off about 115 and goes back on at like 95.. any way to fix this?
Unread 29-01-2003, 09:28
FRC #1660
also, are we allowed to code it in so that it stops at 125 or so and re-opens at 115? stopping at 115 and re-opening at 95 is making us lose that extra 10 psi.. and with our massive pistons, that's a lot.
Unread 29-01-2003, 09:50
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
Actually those settings are hard coded to the switch this year...
Unread 30-01-2003, 02:20
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
The maximum allowed system pressure is 120 psi, so I wouldn't recommend trying to get it up to 125 psi, and I don't believe there will be any discernible difference between 115 and 120 psi.
That being said though, you can use code similar to what we used the last two years. Just figure out how long it takes your compressor to raise the system pressure from 115 to 120, and after the pressure switch opens, continue running the compressor for that long.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 30-01-2003, 21:12
This is NOT a legal (or safe) way of doing it. The pressure switches just aren't designed to handle all the current drawn by the compressor and relay. You MUST use the switch to control the relay from within the software.
Unread 31-01-2003, 03:16
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Last year, we had 2 pressure switches. We used one to turn off the compressor and the other one to turn it back on. So far I have only seen one this year. Are we missing one? If not, any idea on the best way to program the robot for just one pressure switch?
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 31-01-2003, 03:52
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
There is only a single because the one switch acts as two switches. It opens as 115 and it closes at 95 or something like that. So it can easily be programmed like it were two.
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
