Go to Post Pro-tip: Friends don't let friends play defense! (in qualifications) - Mr. Lim [more]
Unread 06-01-2003, 00:20
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
The New PBASIC
OK, I've figured it out, and in case anyone wants to get started, here are the new commands and the ways you can use them. Use at your own risk as it is possible Parallax will never release the updated editor and your code will be worthless:
1. NEW IF SYNTAX! There's two, actually.
The first is:
Code:
if condition then
code to execute if condition is true
else
code to execute otherwise
endif
The second is:
Code:
if condition then statement
These should make people happy as if statements now work like you're used to from C/Java/etc.
2. SELECT. Almost exactly like C's switch:
Code:
SELECT variable/expression
CASE value1
commands
CASE value2
commands
ENDSELECT
3. DO...LOOP. Like do/while.
Either the DO or the LOOP can be followed by the keyword WHILE or UNTIL. Putting it on the DO will cause it to be checked before executing any of the body. Putting it on the LOOP will cause it to be checked only after the body has been executed at least once. Examples:
Code:
DO
commands to execute
LOOP
-or-
DO WHILE condition
commands to execute
LOOP
-or-
DO
commands to execute
LOOP WHILE condition
There's one other new one, but I can't remember what it is at this time. Something similar to BRANCH, if I remember correctly.
Hope that helps.
--Rob
P.S. RoboEmu 1.09 will support all these new commands and should be done tomorrow afternoon.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
