Go to Post There can be only one.... - Koko Ed [more]
Unread 06-01-2003, 01:02
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Dr. Joe's Advice Work on new Boschs?
Do the specifications that Dr. Joes two white papers on the Bosch 3/8" drill still work for the slightly larger 1/2" drills?
Our team has yet to open the kits, so I can't look for ymself just quite yet....
-Rc
Unread 06-01-2003, 12:30
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
I'm not sure what specs you are refering to.
The famous "Dr Joe's drill motor shaft" will probably need to be modified to work in the new motors. But with the new hardware, it might not be as necessary to use it. There are a few people trying to take these trannys apart and see what is going on in the output stage. I haven't heard of anybody succeding yet. The as is set up may be acceptable, but we don't know yet. Personally I'd rather not deal with left handed screws (many bad memories, shudder), so we'll try and do something once somebody figures out how to get the thing apart without destroying it.
If you're talking about performance information, then yes it will certainly be different. Though from what I've seen if you use the old info you will have a very conservative design. The old data is certainly a good starting place.
Christopher H Husmann, PE
"Who is John Galt?"
Q&A Discuss: Dr. Joe's Advice Work on new Boschs? CD47-Bot Extra Discussion 1 06-01-2003 22:18
WARNING...Dr. Joe's advice on the drill shaft is incomplete! archiver 2000 5 23-06-2002 22:31
WARNING...Dr. Joe's advice on the drill shaft is incomplete! archiver 2000 0 23-06-2002 22:31
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
