Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 06-01-2003, 06:31
PaPPy PaPPy is offline
AKA: Brian Papile
None #0069 (HYPER)
Rookie Year: 1998
PaPPy is on a distinguished road
Send a message via AIM to PaPPy
Stacking Question
OK if you have multiple stacks do they add together?
Or is it just the highest stack?
If you take the highest stack do you get points for the other stack?
Example if you have a stack of 4 and 3 do you get multipler of 7 or 4? And then do you get the 3 stack added on as points to b e multiplied?
I hope i made some sense. If you can answer me before 230 today that would be great. Thanks and good luck!
~-PaPPy-~
Unread 06-01-2003, 06:45
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
If these are all in your zone:
Code:
  [_]       [_]
  [_]       [_]  [_]   _
  [_]  [_]  [_]  [_]  [ ]
  [_]  [_]  [_]  [_]  [_]
   4    2    4    3    2
Highest stack is 4, that becomes your multiplier stack.
Your score is now: 4 x (2 + 4 + 3 + 2) = 44
<edit> math corrected. </edit>
Unread 06-01-2003, 07:00
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
Code:
  [_]       [_]
  [_]       [_]  [_]   _
  [_]  [_]  [_]  [_]  [ ]
  [_]  [_]  [_]  [_]  [_]
   4    2    4    3    3
Your score is now: 4 x (2 + 4 + 3 + 3) = 48
(The second 3 is due to the box not meshing with the second box thus raising it into the 3 zone)
Reply if that doesn't make sense to you.
Wrong, if the one 3 is made by one box not meshing with the other, then you have 4 x (2 + 4 + 3 + 2) = 44
the not meshing thing only counts for stack height.
DOX
At VT! Guess I'm unofficially part of 401 now...
Unread 06-01-2003, 08:24
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
Ok, thanks a lot. I corrected it in my post. I wrote that at around 6:30 this morning and wasn't thinking straight.
Unread 06-01-2003, 12:40
AKA: Brian Papile
None #0069 (HYPER)
Rookie Year: 1998
if u have bins flipped up on a side or upside down they dont count like the multipliers
they only count the bins out there to be multipled so the orginal post would be right
so u take the multipler and times it by every other bin out there depending on if its stacked horizontal vertically and w.e else as long as not touching your robot
~-PaPPy-~
Unread 06-01-2003, 12:53
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
from what the rules seem to state, all bins supported by either a portion of the alliance-colored carpet or supported by another bin which is supported by the a-c carpet (and those above it) get multiplied by the height of the highest bin and that which supports it.
stacking robots at regionals Ryan Albright Regional Competitions 5 16-03-2003 08:19
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
