Fisher Price Motor .. Important!
I have just verified with an engineer from Mabuchi Motors. The motor we received in the kit is NOT the same as last year. It is NOT a Johnson Electric motor. The part number displayed on our kit motor (on a sticker) is 74440-0640. The Mabuchi part number that corresponds to that motor is RS-550PF-6534. I will have Brandon attach the spreadsheet, because it is too big for me to do. Key information is:
Stall T = .382N-m Free speed = 15,000 RPM Free Amps = 1.1 Stall amps = 57 I am still working on the others, Paul |
Thanks for the info Paul.
Re: Fisher Price Motor .. Important!
...And THANK YOU for sharing that! (Talk about Gracious Professionalism!) That note may have just saved the bacon on a LOT of teams! That's a 25% lower free speed than the old FP/Johnson. I can envision a BUNCH of teams scratching their heads in weeks 3-6 wondering "what the heck did I do wrong with my calculations ??", when it didn't "rev up to spec". Major props for Paul... NOW I'm VERY curious about the OTHER "big boy" motors! When you find/determine the other motors' specs, can you please post the links to their data sheets too?Thanks again! - Keith |
Does anyone have information on the Fisher Price motor pinion?
I took mine out today and much to my surprise it has 19 teeth, and each tooth looks a bit "fatter" than the ones we got in 2001, so I assume it is less than 32 DP. I do not have a good way to measure the DP and Pressure Angle... I should get some tools to do so at some point. |
Still 32 DP
The Fisher-Price is still 32DP, but it is 19 teeth. I just measured several of the "over pin" dimensions as well as mated it up to some other 32 DP gears.
-Paul |
Pressure angle?
Paul, or others,
Do you know what the pressure angle of the stock FP pinon gear is? Is it 20 deg or 14.5? Thanks! Simon |
DP of FP
20 degree pressure angle.
-Paul |
| Need Fisher Price Motors | kevinw | Motors | 1 | 02-13-2003 06:44 PM |
| Multiple Fisher Price Motors? | authgeek1218 | Motors | 5 | 01-10-2003 10:48 AM |
| Fisher Price Motors for Drill Motors | archiver | 2001 | 0 | 06-24-2002 12:22 AM |
| New Fisher Price Motor - IMPORTANT | Paul Copioli | Motors | 6 | 02-08-2002 01:35 PM |
