Go to Post We only ask that, when able, you too help other teams as we have helped you. It is this mentality of passing it forward that makes teams and FIRST great. - E. Wood [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #16   Spotlight this post!
Unread 07-01-2003, 15:38
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
very true, an experienced driver will learn to press the button. I feel that my duty as a programmer is to make the robot as user friendly and easy to drive as possible. Perhaps find a happy medium, use both buttons and joystick movement? or better yet, make any operator input snap the robot out of auton_mode
  #17   Spotlight this post!
Unread 07-01-2003, 21:12
Goya Goya is offline
#0019 (Big Red)
Goya is an unknown quantity at this point
Send a message via AIM to Goya
What about the simple solution?
Having the driver pass retina, blood, urine, fingerprint and password-protected tests before allowing the joysticks to control the robot?
(Wink, Wink) ;-)
  #18   Spotlight this post!
Unread 08-01-2003, 00:14
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
Rookie Year: 2000
rwaliany will become famous soon enough
hrmm
That might be a good idea having a button to snap the robot out of auton mode. Well, if the robot is doing good by itself, the question comes to mind: why should the driver drive?
- Ryan
R
  #19   Spotlight this post!
Unread 12-01-2003, 03:36
chewie chewie is offline
chewie is an unknown quantity at this point
how is auton_mode set?
How is the auton_mode bit set? does the RC set it to 1 when the OI is off or no radio signal... (due to power cut for autonomous play) or is it get sent from the OI some how...or perhaps is it something else, i mean how does the competition control it? Anyone know this yet? I havn't been able to find it anywhere.
Thanks.
Nick Falletta
  #20   Spotlight this post!
Unread 12-01-2003, 05:30
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Originally posted by Morgan Jones
I think in my code, I will have the robot continue in autonomous mode until it receives input form the OI. That way, if the robot is doing fine by itself, the driver can let it continue on its own for a while longer. As soon as the driver needs/wants to take control, s/he just has to grab the joysticks.
Why do this? Won't a human driver invariably be better than a autonomous one in? It's not like you need to be calculating re-entry trajectories or something that actually requires computer calculation. I can't see a circumstance where having the robot continue autonomously will be better than having the driver do his/her thing. Englighten me.
0N3 1337 PR0G|24MM1N6 N1NJ4
  #21   Spotlight this post!
Unread 12-01-2003, 09:05
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: how is auton_mode set?
See this. At competition the autonomous mode will be set using the competition port. There must be a radio link established from the OI to RC for the robot to operate, either in autonomous mode or normal mode.
  #22   Spotlight this post!
Unread 12-01-2003, 11:41
Morgan Jones Morgan Jones is offline
Morgan Jones is an unknown quantity at this point
You're most likely right, and I can't think of a particular circumstance where my method would be necessary. However, we're only a little into the second week, and I have no clue what my robot will be capable of and exactly what it will be doing in the autonomous period. Therefore, at present, I am still planning to use any input to deactivate autonamous mode. I may change my mind in the future, but not yet.
Morgan Jones
Team 578: Fairport High School/Gleason Works
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
