OCCRA
Go to Post The energy source of the future is brain power. - Michael R. Lee [more]
CD-Media
Unread 01-02-2018, 08:48 PM
deusXmachinist deusXmachinist is offline
AKA: Annie
FRC #0900 (Zebracorns)
Rookie Year: 2015
deusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond reputedeusXmachinist has a reputation beyond repute
paper: FRC Battery Upgrade
Thread created automatically to discuss a document in CD-Media.
FRC Battery Upgrade by deusXmachinist
Unread 01-02-2018, 08:49 PM
marshall's Avatar
marshall marshall is offline
"Who's Marshall?"
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: paper: FRC Battery Upgrade
Happy to answer questions about this if you have any!
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
Unread 01-02-2018, 08:59 PM
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Which wire are using? Did you have to cut any strands to get it into the SB50 crimp?
We found using multiple heat shrink layers over the bolted connection helps keep things in place.
I like the washer setup and will likely start doing that, we had been using internal star washers but your setup looks better.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 01-02-2018, 09:06 PM
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
Cynicism isn't wisdom
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
The total cost for each cable we made was less than $10.00
vs
http://www.andymark.com/12-inch-robo...-p/am-0009.htm
Nice!
We are currently using 97527A005, the king of all lockwashers, but after seeing how clean this solution is, I'm also interested in trying some of these Nordlocks.
What crimper are you using? Is it really pneumatic? We've been using the Harbor Freight cheapo hydraulic crimper and it's just fine.
Good work Annie and Levi!
Unread 01-02-2018, 09:12 PM
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Are you really gaining an advantage by using two sets of washers?
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
Unread 01-02-2018, 09:18 PM
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
Rookie Year: 2010
chadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to behold
I love nord-lock washers. Is there any reason why you use 2 sets per connection? It seems like one on the bolt head side would do the trick.
Unread 01-02-2018, 09:20 PM
Mike Marandola's Avatar
Mike Marandola Mike Marandola is online now
Trust the Process
AKA: Mike Marandola
FRC #0316 (LUNATECS)
Rookie Year: 2007
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This is extremely helpful. To someone with more electrical knowledge than me, how much of an effect does thicker battery cables have on performance?
LUNATECS.org
FRC 316 Student 2007 - 2011
FRC 316 Mentor 2012 - 2017
FRC 316 Lead Technical Mentor 2018 - ?
Unread 01-02-2018, 09:33 PM
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Where did you source your SB50 connectors with 4 gauge lugs? The SB50A at Andymark only come with lugs for 6 gauge.
The same 6 gauge lugs from Powerwerx, plus those SB50SB's don't match up with FRC connectors.
Getting new SB50 could double your $10 budget on this.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 01-02-2018, 09:35 PM
Billfred's Avatar
Billfred Billfred is offline
Another day, gotta give 'em hell
AKA: It's burning straight through the dark...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
4 AWG over 1 foot (each side) at 12V and 120A load is a 0.060V drop.
6 AWG, .095A.
It gets more pronounced if your robots have higher current draws, longer wire runs, or crappier crimps--but there's your baseline. I'd be inclined to tackle other places first (especially upping drive motors from 12 AWG to 10 AWG, which has a higher percentage effect, and shortening runs there), but if you're sweating every bit of your battery voltage that's one to do as well.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
117 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 01-02-2018, 09:40 PM
FRC #2363
Team Role: Coach
Rookie Year: 1999
Yeah, I don't know if I have more electrical knowledge than you, but it looks to me like if your robot is wired with 36 inches of red and black 4awg, and you're drawing 240 A, it would give you access to an additional tenth of a volt at your PDP.
[240 A * (.3951-.2485 ohm) * 36 in]/(1000 ft) = .1 V
Unread 01-02-2018, 10:07 PM
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
I think the reduction of waste heat is a more significant improvement.
0.1056 Volt x 240 Ampere = 25.3 Watt.
With 6 AWG, that extra wasted power is heating the cables, and that heat is flowing from the cables to their contacts; cycles of that heating, with cool-off periods between, accelerate loosening of those contacts. When contacts get too loose, they will exhibit momentary high resistance during mechanical shocks, causing brown-out. Because the contacts are hidden under insulation (tape, heat shrink, or connector housings) they don't get inspected and their failure comes as a surprise.
With 4 AWG, that 25.3 Watt goes to the PDP as usable electric power, putting less cyclic thermal stress on contacts and allowing the robot's electrical system to do more.
Richard Wallace
since 2003
Unread 01-02-2018, 10:36 PM
marshall's Avatar
"Who's Marshall?"
It's just 4awg wire from Amazon with decent strand count (370) - Price has increased by slightly more than $6 since we ordered it:
http://a.co/9MzuKmN
We did not cut any strands and the students took their time using the correct stripping tool (http://a.co/1c9esHm) for this gauge of wire and then carefully slid the wires into the 6awg connectors.
More on the washer setup in a minute...
vs
Nice!
The crimper is not pneumatic... I'll pretend it's an allusion to the hydraulic arm video from FIRST and not a mistake though.
Advantage? No... but we are using them the way Nord-lock recommends.
Yes, that's how they say to use them: http://www.nord-lock.com/nord-lock/w...s/joint-guide/
I have no idea why you think they don't match. See above info about lug sizing. Also, price with new SB50s doesn't break the bank and since you don't believe me, you can do some math:
  • SB50: $1.24
  • 1 ft Red cable: $1.00
  • 1 ft Black cable: $1.00
  • PP75/SB50 Loose Piece Contact (Gauge: 6): $0.58
  • THOMAS & BETTS 54906BE 4 AWG LONG BARREL 1/4 " SINGLE HOLE - BLIND END: $0.80
  • 10-32 Nylock Nut: $0.09
  • 10-32 Bolt: $0.23
  • 10-32 Bolt: $0.23
  • Nord-lock Washer: $0.52
  • Red Heatshrink: $0.39
  • Black Heatshrink: 0.39
Clarke's Laws
Last edited by marshall : 01-02-2018 at 10:47 PM. Reason: Edits to fix minor things.
Unread 01-02-2018, 11:08 PM
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
  • SB50: $1.24
  • 10-32 Bolt: $0.23
  • 10-32 Bolt: $0.23
Easy Hoss,
I'm not trying to start a war. I think they don't match because I just ordered one of these for our new battery analyzer (https://powerwerx.com/anderson-sb-connectors-sb50-50amp) and it doesn't match any of the FRC connectors on our batteries without significant modification!
Also, my question was for where you sourced the SB50 with 4 gauge lugs. Your paper does not state that you are using 6 gauge lugs. That makes a difference, look at the 4 gauge options and the price climbs.
While, I know this is a safe practice; with some of the inspectors I have ran into the last two years, justifying jamming a 4 gauge wire into a 6 gauge lug, is a battle I'm not willing to take on right now.
Clint Brawley
USAF 1992-2013
Unread 01-02-2018, 11:09 PM
chadr03's Avatar
Rookie Year: 2010
Interesting... I've only used them on studs in industrial applications, but after seeing your post and thinking about the locking mechanism it makes since to need them on both sides of a bolted connection.
  #15   Spotlight this post!
Unread 01-02-2018, 11:10 PM
marshall's Avatar
"Who's Marshall?"
Easy Hoss,
Did you order a color other than red? I don't know what you mean by it doesn't match? Got pictures?
Clarke's Laws
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
