Go to Post Must...squish....bugs... :p - nighterfighter [more]
Unread 08-01-2003, 00:23
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Robot Controller
In the manual, it says that anything you get in the kit of parts can be put on your robot. Since the parts of the robot control panel come with the kit of parts, and it is unreasonable to expect a robot with two joysticks mounted on it, can it be assumed that the device you use to control your robot counts as part of the robot itself?
If it does, how far does that extend? The cost limit? the weight limit?
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
