Go to Post All screws are not created equal. - Al Skierkiewicz [more]
Unread 08-01-2003, 08:52
Martin Martin is offline
#0907 (East York Cybernetics Core)
Martin is an unknown quantity at this point
Send a message via ICQ to Martin
snad paper
sand paper as traction for the carpet ? good or not ?
it would not do any damage, we would definitley haveto have a high torque low speed option if we were to do that, just becasue there is so much friction...but as long as it didn't damadge the feild is it ok ?
thanks
2002 - 3rd seed
2002 - highest rookie seed award
2002 - J&J sportmanship award
Martin
907
Unread 08-01-2003, 09:08
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I suppose it would probably be allowed, since it wouldn't really damage the carpet, however, I do not think it would be a very good surface for traction. You must also keep in mind that you cannot put anything on a purchased wheel. If you want to use your own traction material, you must build your own wheels.
EDIT: I received a pm from someone, and they had a good comment:
2000vfr800 wrote on 01-08-2003 10:36 AM:
My reply was in response to using sandpaper for traction. While it might not destroy the carpet, I do believe that it would scratch the HDPE or surface of the metal grate ramps... And since the rules say you can't destroy/damage any part of the field, it might get you disqualified.
Just my $.02. Thanks.
Don
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 08-01-2003, 11:05
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Martin,
We used heavy grit sandpaper last year on the wheels with some success but the level of traction greatly changed throughout the days as the samdpaper filled up with threads from the carpet and the carpet became worn and flat.
I think sandpaper will have issues getting up the ramps and it will probably take off the paint which might be considered damaging the field same for the plastic topper.
We unded up using the supergrip material similar to brecoflex that stayed much more consistent throughout the days of the event
Also the sandpaper is VERY difficult to overcome on a side load for your robot to turn with tank steering.
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
Good luck to all at Nats Ben Mitchell Chit-Chat 0 18-04-2002 19:59
