Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
View Poll Results: What will be the most effective robot this year? (select all that apply)
Ball Harvester w/Dumper 20 23.26%
Ball Harvester w/Direct Deposit into Goals 29 33.72%
Goal Controller (1 goal) 24 27.91%
Goal Controller (2 goal) 42 48.84%
Goal Controller (3 Goal 19 22.09%
Bully Bot (take out balls from goals) 12 13.95%
X-tendo bot (extends to reach Home Zone) 20 23.26%
Ball Shooter 14 16.28%
Speedy Robot 36 41.86%
Powerful Robot 49 56.98%
Multiple Choice Poll. Voters: 86. You may not vote on this poll
Unread 09-01-2002, 18:20
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Team Role: Coach
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
What will be the most effective robot type this year
vote so we can compare the results of the poll to the results of competition
Like Aquidneck Island Robotics on Facebook!
Unread 09-01-2002, 18:40
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
Rookie Year: 2000
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
3 goals would yield a low score for your oponents and thus you would get a low score also.
Unread 09-01-2002, 19:15
tjrage_25's Avatar
tjrage_25 tjrage_25 is offline
Mentor
AKA: Tom McLean
FRC #0025 (Raider Robotix)
Rookie Year: 2000
tjrage_25 is an unknown quantity at this point
Send a message via AIM to tjrage_25
You would get a low score in qualification rounds, but being able to keep the opponent's score very low will come in handy in the finals if you get picked.
Unread 12-01-2002, 21:28
Benji Benji is offline
Benji is an unknown quantity at this point
3 goals
youll get picked for the elimination matches if u win all ur qualification matches
Unread 12-01-2002, 21:41
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
With a dominating capability like that, I think it is likely you'd also get picked for finals... I mean, if a robot can grab all 3 goals it effectively dominates the playingfield... in the finals who cares about balance... shut em out, by giving them NO way to score...
Unread 13-01-2002, 00:36
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
A three goal controlling robot wouldn't necessarily be a three goal scoring robot. A robot could hold all three in the center of the field, rotate, and effectively fine-tune the score to whatever it needed to be by rotating.
The trouble is building a robot that, once it has the three goals, can do something with them. - those goals are huge lever arms. up against two quality robots, could easily be pushed around by a robot at the end of the goal - unless they've already thought of that.
Oh no!! I've said too much!
Unread 13-01-2002, 01:34
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
Rookie Year: 2000
The goals may be lever arms, but they turn a 130 lb robot into a (assuming 180 lbs/goal) 670 lb robot. That's quite a large unyieldy mass to move...
Unread 13-01-2002, 09:49
Dave Hurt Dave Hurt is offline
Mostly Harmless
FRC #6413 (Degrees of Freedom)
Rookie Year: 1999
Dave Hurt is on a distinguished road
Benji, that's not entiraly true...
In '99 I drove 308's machine to be 6-0, one of only 2 teams to do that. We didn't get picked up. It's all how you market yourself and the luck of the draw.
Just don't forget about those ball handelers.... with a good ball harvester you only need 1 goal to win....
Unread 13-01-2002, 22:10
mrobrien mrobrien is offline
#0972 (Steelpaws)
mrobrien is an unknown quantity at this point
Send a message via ICQ to mrobrien
one goal speedy direct deposit
If a speedy robot can get one goal and fill it up with 30-50 balls in under 40 seconds while avoiding having the goal stolen (I'd think it'd be hard to steal a fast moving goal with an evasive driver) as one of our designs should be able to do, that's 50-70 points assuming that our partner gets ten points (at least) by just sitting there. This seems easier to me than trying to chase down and catch all 3 goals, getting you 40 points vs 30 MAX assuming the same thing about your partner. Also, if the balls are in the game, it will probably be a much higher scoring match and thus give a higher multiplier to the winner.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Image Discuss: 810 - Minotaur: Coming to a regional near you. CD47-Bot Robot Showcase 47 25-02-2003 16:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Basedoes this type of robot seem like it would be picked? Mullen Regional Competitions 3 14-03-2002 11:42
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
