deadline
arg! if anyone has any clue about the specs contribute it, seeing as we all need the drive trains finished soon, in my case Monday (originally), but without output data, I'm not sure I'll meet that deadline for my team. also, if anyone can clear up the figures given on sprockets by MSC, it would be appriciated seeing as I'm at a disadvatage with no engineer help this year.
Look Here
I have compiled the data. Most of which is in the manual where the drill motor is listed, but I had to experimentally determine the free amps.
Look here: http://www.chiefdelphi.com/forums/pa... SC&sort=date You will find data for the Fisher-Price, Drill and Chiaphua. I am 100% sure about the Fisher-Price and Chiaphua, but 95% sure about the drill. From my initial test, the numbers look good. The link is to the white papers section from a presentation I gave at the Novi Kickoff. I updated the motors with the new information. This should be enough for you to get working until FIRST gets their numbers together. Please note that there is another white paper regarding the Fisher-Price motor that I posted. It is the motor manufacturers data sheet and it corresponds with my number in the presentation. -Paul |
thank you
a word of advice. if get the brilliant idea of hooking the drill motor and gearbox directly to the battery
, be sure u are holding both parts of the transmission. This tranny does not stay together well!! |
Drill Specs
The specs for Bosch 3360 drill, which is where I'm guessing this motor comes from, on the boschtools.com web site lists the drill as having a stall torque of 400 lb-in (45.3 N·m) and a no-load speed of 450 rpm in low gear. Doing a little math that gives it a stall current 185A at 12V and a peak power output of 527 watts. In high gear you'd get stall torque of 12.7 N·m and a no-load speed of 1598 rpm and with no gear box you'd get stall torque of 1.06 N·m and a no-load speed of 19170 rpm.
Greg Enigma Industries Last edited by gc02 : 12-01-2003 at 21:41. |
The motor stall torque is also in the parts list, this times the reduction ratio and assume the efficiencies are similar to the old transmissions, 80% in high and 70% in low. This will get you most of the way. Remember the torque of D.C. motors is linear between max at stall and 0 at free speed RPM.
has anybody gotten the specs from the manufacture? I must have missed the specs and I am looking all over for the specs from the manufacture. Can anybody help. Please attach the file to the forum and I will get back to it. Thanks.
Code:
Drill motors: 19670 RPM Drill motors (with gearbox in low): 461.52 RPM Drill motors (with gearbox in high): 1629.66 RPM |
First posted a bunch of specs today:
http://www.usfirst.org/robotics/2003/specsheets.htm Be careful though, the "drill motor" specs seem to be for two different motors. Was there more than one type of drill motor in the kit? Greg Christensen Enigma Industries |
#10
thank you
I bow down to your superior ability to stand the first ability to not post things and hunt them down! now maybe I can actually get some work done! thank you!
#11
Did anyone else notice that the Drill Motor curve is for motors running at 11V? Any ideas on how a 12V setup would compare? I'm guessing it's almost identical, but then again, strange things happen when you up the voltage to motors.
#12
Just a thought! |
#13
I'm even more confused by the drill motor gear specs (assuming that's what they specify). From the looks of things, it specifies a 13 tooth gear at a 20 degree pressure angle. Now, I counted the number of teeth on the output gear of our motors. It was most definitely 15 teeth. I only counted one motor but I'll check out the other one tonight. Anyone know what's up with that?
Matt |
#14
It Checks Out
The part number on the motor data curve IS the same number as printed on the motor. The FIRST manual is inaccurate. The raw numbers printed in the chart for 12V (lower left corner) checks out with what FIRST gave us and with what I noticed for free amps.
-Paul |
| Portable cordless drill press | Gui Cavalcanti | Technical Discussion | 25 | 03-08-2003 22:21 |
| drill motor mounts- again | Jeff Sharpe | Motors | 6 | 07-04-2003 23:20 |
| Emergency drill trade/sell | Anarkissed | General Forum | 3 | 16-02-2003 22:37 |
| Q&A Discuss: HOT drill motors | CD47-Bot | Extra Discussion | 1 | 27-01-2003 13:31 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
