Go to Post Just make a FIRST version of Quidditch. The only people who would be complaining are drivers from previous years who wanted to play it. - Koko Ed [more]
Unread 08-01-2003, 17:49
imjustmatthew's Avatar
imjustmatthew imjustmatthew is offline
#0638 (Operation Oxidation)
imjustmatthew is an unknown quantity at this point
Send a message via AIM to imjustmatthew Send a message via Yahoo to imjustmatthew
"Dave" might be right...
I think "Dave" might be right, the Rc has to have a radio or tether downlink before it will initalize, even in autonomous mode. Therefore the OI must be powered during the autonomous control segment. It would then only make sense that the reset button would work during the autonomous segment.
However, I wonder wether or not scratch pad ram is erased during a RC hot reset? If its not you could potentially create a secondary "safe" AI program that will load when a "dirty" byte is in a given scratch pad slot, that way if your primary AI routine fails for whatever reason, you could set the robot to automatically use a "safe" default type routine.
I might be of on the reset button and scratchpad, but it might be worth a shot.
Matthew Roy
"We propose to decompose the competition."
