Optical Sensor Questions
been playing with the Edubot and the optical sensors in this years kit at home for the past couple of days.. and i noticed someting a little pecular about them.
they will sense other surfaces then Retroreflective tape.. i hold my hand in front of them and thet trigger. also.. i built a model of the sensor array we plan for the bot this year and im finding out that the sensors have a hard time tracking white on red. im using construction paper, but i dont have any carpet. anyone else encounter this problem or a simalar one? the other thing is.. that im not totally shure about the tracking lines on the field this year, are they made with retroreflective tape or is it just a strip of white duct tape ~Pyro |
It's actually more of a cloth tape. The reason for this is that it stretches to make the 4' radius better. The sensors don't require retroreflective tape, they can also detect differences between light and dark.
you can also adjust the the little screw on the back of the sensor to decrease or increase the difference between white and dark or other colors
just play around with the screw on the back |
Team 852 has had the same problem.
I believe that the sensors emit and track red light (low frequency within the visible spectrum), not infrared. I still need to look at the charts they sent us. Red light emitted from the sensor reflects very well off of red paper (Red paper is red because it reflects red light, and absorbs a good bit of the other frequencies). We have not tried it on red carpet, and wonder if anyone else has made such an attempt. Of course, if so, what were the results? -DB, The Athenian Robotics Collective |
| optical sensors | majormusic2005 | Electrical | 5 | 11-03-2003 21:32 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| optical sensors | great_one411 | General Forum | 1 | 15-02-2003 19:54 |
| optical sensors | majormusic2005 | General Forum | 1 | 28-01-2003 20:37 |
| OPTICAL SENSORS??????????????????? | NM_programming | Technical Discussion | 2 | 13-01-2002 17:41 |
