Go to Post Sometimes people are just offended too easily. Sometimes offensively so. - GeeTwo [more]
Unread 08-01-2003, 21:59
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Best source for gears? Smallparts? drivetrain advice wanted!
We need to build custom gearboxes . . and I am put in charge of getting a basic sketch down. I have one using smallparts carbon-steel gears and sprockets, the Atwood/Chiaphuas, and the Bosch drillmotors and transmissions.
the thing is, using the sprokets and gears from small parts, my ratios are off by about .02:1 . .
like, I want one to be 1.3:1, best I can get is 1.28:1
Is this a problem, will my motors burn up if they are out of ration by 1 or 2 percent (ratios for both motors are a bit low, so maybe just <1%)?
Also, whats a reasonable speed/force? My current design gives us 10 m/s and about 350-400 Newtons (200-250 up the ramp)
I have no idea about efficiency either, so I just random-guessed 60%. This is high or low?
Im using Bosch to transmission to one gear-gear connection, then to the sprockets to drive the wheels, and Chip/Atw. to gear-gear connection to sprocket to wheels. Can I hope for higher efficiency? All parts are from smallparts with a total materials tab of ~$215.00, not including the chain or housing materials or axels, just gears and sprockets.
#%#%#%#%, we are really jumping into this. I have never designed a drivetrain in my life . . and our moderator says "Ok, so why don't you sketch out a drivetrain and chassis for us and bring it in thursday or friday. Ok, greeaaat. And Bob, could you sketch out the bulldozer arms?"
I always get the hard part.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
advice on drivetrain ark_1230 Motors 4 14-01-2003 23:12
