Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
  #16   Spotlight this post!
Unread 15-01-2003, 18:50
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Yeah, somebody else just told me about that last night. I'm now hitting my head against my desk repeatedly for adding a call to removeSpaces withing the makeCmdIf function. Stupid, stupid, stupid, stupid, stupid...
Look for yet another new version by tomorrow night.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
  #17   Spotlight this post!
Unread 16-01-2003, 22:01
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Rookie Year: 1996
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Modulus operator?
Does RoboEmu support the modulus operator (//)? I have a statement:
Code:
if (CCDataIn <> ((PrevDataIn + 2) // 256)) then
and it give the error "Error: Variable /256 does not exist. Can't get value. While processing If @((CCDATAIN;((PREVDATAIN+2)//256)))"
Thanks for the tool, it's been a big help while we're sitting around waiting for a robot to play with.
Mike
  #18   Spotlight this post!
Unread 16-01-2003, 22:03
Ooops. Kinda forgot that one. Look for it in 1.10 as it definately should be there.
  #19   Spotlight this post!
Unread 21-01-2003, 07:37
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Does the RoboEMU support delta_t?
  #20   Spotlight this post!
Unread 21-01-2003, 09:09
No. It wouldn't really work, either, due to the speed differences between computers. If I figure out a way of making it work, I might add it. Anyway, 1.10 is done now, so grab that.
  #21   Spotlight this post!
Unread 21-01-2003, 15:07
rust710's Avatar
I have the 1.10 but I posted in the wrong forum. Thanks for the response. What will the program do when it incounters delta_t?
  #22   Spotlight this post!
Unread 21-01-2003, 17:08
I honestly don't know. It shouldn't crash, but it may return some insane number. Let me know if you find out.
  #23   Spotlight this post!
Unread 21-01-2003, 17:22
rust710's Avatar
Well I tried it and it just returns a 0. Which actually is fine. The Stamp will return a 0 if the code is executed in 26ms or less. So my code works fine. delta_t has to be declared and is in the serin so it acts like a varible not set.
One thing that you program doesn't support is toggle. For example toggle 15 changes the state for one of the relay lights. Really same as out15 = ~(out15).
I really like your program. I have been using it even when I have a robot controller because it is easier to setup.
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
PBASIC 2.5 Questions Noah Programming 6 10-01-2003 19:26
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
