Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
Unread 09-01-2003, 20:34
DuDaKyD's Avatar
DuDaKyD DuDaKyD is offline
#0237 (Sie-H2O-BOTS)
DuDaKyD is an unknown quantity at this point
Send a message via AIM to DuDaKyD
Bar Height
Does anyone know the exact height from the carpet to the bottom of the first bar that are attached to the ramp?
Unread 09-01-2003, 20:35
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
14 1/2". around there
Unread 09-01-2003, 20:36
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
14"?
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
Rookie Year: 2000
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
do you mean the ones that are on the left and right sides?? if so its 14 inches
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 09-01-2003, 20:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
It was my understanding the hieght was 14 3/4. Can a moderator clarify this?
Unread 09-01-2003, 21:10
DuDaKyD's Avatar
i don't think FIRST has clarifyed the exact height, we just know a bin can not fit under them in any configuration
Unread 09-01-2003, 21:12
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
14 3/4 inches, they did specifiy this. but if you plan to go under, design it lower so you don't get stuck on it
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 09-01-2003, 21:17
Digo's Avatar
Digo Digo is offline
AKA: Rodrigo Ribeiro
#0383 (Brazilian Machine)
Rookie Year: 2000
Digo is on a distinguished road
Send a message via MSN to Digo
I remember from 2001 that sometimes they don't say the distance between important things, they only say what parts you need to build it, and than you can go measure it.
The goal we built in 2001 was "similar" to the real one, so I had to call FIRST and asked someone to measure some important things for me in order to design a claw to get the goal.
Rodrigo Ribeiro
Team #383 - The Brazilian Machine
Mechanical Engineering student at UFRGS - Porto Alegre - RS - Brazil
Unread 09-01-2003, 21:58
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Download the "field blueprint" from First. The Bars' heights are shown at 16 and 20 inches, I believe. I just had a glimpse tonight.
Unread 09-01-2003, 22:08
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott3137
FRC #3137 (T-Birds)
Rookie Year: 1999
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Be careful...
I haven't seen the drawings, but from different threads on the same topic, I believe 16 and 20 do not represent numbers that answer the original question.
I keep hearing 14.75" as the answer to the clearance, but obviously this needs to be clarified on the FRC site.
The only thing you can be 100% sure of at this point is since the container cannot pass under, it's lower that the height of the container (which is 15.75").
Regards,
Scott358
Unread 09-01-2003, 22:21
Engineer/Mentor
AKA: Scott3137
FRC #3137 (T-Birds)
Rookie Year: 1999
Answer from FRC site....
Distance to the top of the bottom bar is 16".
Outside diameter of schedule 40 pipe is 1-11/16".
If copy and paste works, here's the link:
http://jive.ilearning.com/thread.jsp...t=15&trange=15
If you do the math, that would be 16" minus 1-11/16" = 14-5/16".
Regards,
Scott358
Unread 09-01-2003, 22:54
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
The carpet has thickness too. How does that affect your measurements?
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
Bar Height archiver 2001 10 23-06-2002 22:54
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
height questions Team461 Off-Season Events 3 29-10-2001 21:51
