Go to Post However I do wish to reassure people that the judges did not just fall off the back of a turnip truck... - dtengineering [more]
Unread 10-01-2003, 16:04
Brett W Brett W is offline
#0843 (WYVERNS)
Brett W is on a distinguished road
Globe Motors?
Why does no one use the globe motors for the drive train? What are the Pros and Cons of the Globe Motors .My thought is, if you gear the globe motors up and gear down the drill motors you would have semi-good speed and pretty good tourque. Please correct me if i am wrong. thanks
Brett
Unread 10-01-2003, 16:34
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Not enough power
First, I will start out by saying you can do anything you want to do.
With that said, I would highly recommend against using the globes for drive motors. The main reason is they do not have the power to justify using them.
Second, by gearing up (increasing speed) you are double dipping on gear ratio. What I mean by this is that the gearbox attached to the globe motor already has a pretty big reduction, so you are "reversing" that ratio to get more speed .. very ineficient.
Last, the shaft on that motor can't take any side load so you need to add another bearing.
It is too much work for not much gain.
If you are going to pick drive motors use the Chiaphua, drill, or Fisher-Price or any combination of the three.
-Paul
Unread 10-01-2003, 20:57
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
Plus I think that the drill and maybe others have protection that holds the smoke inside incase it stalls/overheats.
Unread 10-01-2003, 21:13
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
There are several reasons the Globe is not a good drive motor. First, as was stated above, the motor was designed for axial torque, which means that it doesn't handle side-load well. Second the globes aren't as strong as the other motors. The bosche, FP, and Atwoods are all considerably stronger than the Globe. Lastly the Globe has a very limited range output. It is very close to having just two speeds, on and off. The other motors utilize a wider range in output speeds.
Can you use the spikes with the globe motors? Caleb Fulton Electrical 1 15-02-2003 20:13
globe motors & decoration archiver 2000 0 24-06-2002 00:27
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
hey what bout the globe motors? dandaman Motors 1 08-01-2002 03:03
Drill Motors TF8 Motors 19 12-12-2001 13:13
