Go to Post Be civil in all things and you will get far. - Wetzel [more]
Unread 10-01-2003, 22:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Update #3 & Negative Scores...
The rules as written now seem to allow for huge negative scores.
Did FIRST really think this one through?
This is a huge confusion factor for the audience.
Here is the scenerio.
Assume the Blue alliance has twin Ramp Bots. They quickly go to the ramp, knock down the wall, plop down a couple of toilet bowl plungers and sit tight with the expectation that they have a lock on a win with 50 points in the bank...
But along comes the red alliance with Plow Bot and Tall Bot. Plow Bot methodically pushes all the containers in the blue zone into the no score zone. Tall Bot then picks up a single container and lifts it 11 Stack Height Units.
Red wins.
The score:
Red: 16 (assuming that the human players scored during the first 10 seconds)
Blue: (-10*11)+50 = -60
1 container IN
11 SHU
Multiplier 11
Base score 1-11=(-10)
This is going to be crazy for folks to understand.
Just my thoughts.
Joe J.
B
Unread 10-01-2003, 23:04
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
Two things:
1 - In the scenario as described, base score blue is zero, as the crate held by the robot as the multiplier stack is counted as zero points.
2 - Assuming there was another box still in the scoring zone, that one box would be counted as one point. It's not (B-X) anymore, as the equations have been showing, when you have an opponent supported stack. It's one point for every crate "in" the scoring zone that isn't in the highest stack.
Jacqui Sutton Jacqui Sutton is offline
#0388 (Teamless in Oz)
Jacqui Sutton is on a distinguished road
Send a message via AIM to Jacqui Sutton
The scenario you posted doesn't seem quite clear *maybe it's just me* but; if red team has one of their bot's in the blue teams scoring zone at the end of the game with a box raised 10 SHU high, and the blue team has only 5 boxes in their scoring zone..then it seems as if the score would be (5-11)*11 = -66... it does seem that negative scores are possible.. I hope FIRST will change this, yet again, cause as you said this would definately confuse the audience and also make one specific type of robot dominant after teams have already strategized and begun building robots without this possibility..
-sigh- guess it just makes it all the more of a challenge.
Unread 10-01-2003, 23:10
Originally posted by JTH
2 - Assuming there was another box still in the scoring zone, that one box would be counted as one point. It's not (B-X) anymore, as the equations have been showing, when you have an opponent supported stack. It's one point for every crate "in" the scoring zone that isn't in the highest stack. [/b]
in update # 3 under rule SC8 it says "the height of the tallest stack located in the scoring zone (the "multiplier stack"), measured in whole stack height units (as defined in SC9) is subtracted from the total number of containers to establish the "base score."" - how is that not (b-x)?
Unread 10-01-2003, 23:22
JTH JTH is offline
Oh... I guess I've been reading the rule wrong ever since Team Update 1 came out. I was still thinking the original rule, which considered stacks in the multiplier as zero. Now I really hope that FIRST reconsiders the virtual stack created by opponent robots.
Unread 10-01-2003, 23:30
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
I have a feeling that this is not what FIRST means. And anyway, the bot is touching the stack of 11, so it's not counted.
Love,
Team 384 Rules Nazi
Unread 10-01-2003, 23:34
JTH JTH is offline
The opponent robot in your zone does not affect the eligibility of the stack.
But, my brother suggested that this might make a great blackmail strategy, if you have a really tall armed robot and are going up against a team that is almost guaranteed a top spot. "You know, we'll give you a huge negative QP unless..." How's that gratious professionalism?
Unread 10-01-2003, 23:39
Love,
Team 384 Rules Nazi
it's the oppositions bot that would be touching your stack, so yes, it would actually count.
and i agree, this is definately not in the spirit of FIRST, i dont see why they would do this intentionally?
Unread 11-01-2003, 00:02
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
I asked FIRST about this, and basically got back snide comments about my questions being convoluted and me abusing the forums. I asked FIRST:
The way the rules are currently written, if your opponent's team has x containers in their scoring zone, and you take one of their containers and lift it x wSHUs into the air, their base score is reduced to zero. A robot with a tall enough lifter could easily ensure that their opponents never got any points for containers. Is this correct?
and they replied via email:
Rule SC8 states:
"Opponents robots in contact with containers in the alliance scoring zone will not affect the determination of the base score."
How much clearer could that be.
This lead me to believe that stacks would be measured form the lowest bin, not from the ground, but nowhere in the rules does it say where stacks are measured from. I replied to the email they sent me asking if the height was measured from the bottom container, and they replied:
See Team Updates
Please do no abuse the Team Forum process. Please do not send e-mails directly to FIRST. Use the team forum. You received an e-mail response because I did not want to clutter the Forum with your convoluted question. If you abuse the forum, we will remove your access to it.
Has anyone managed to get a real answer on this issue?
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 11-01-2003, 00:08
Shawn60 Shawn60 is offline
#0060 (Bionic Bulldogs)
Shawn60 will become famous soon enough
Am I wrong? If red gets 16 and blue gets -60 the final score will be
red 16 +(2*60)=-104
Blue -60
Blue wins
Unread 11-01-2003, 00:13
ejthe4th ejthe4th is offline
Active User
AKA: EJ Meyer
#0240 (Mach Vee)
ejthe4th is on a distinguished road
from what i understand the base score is the number of boxes that are in the scoring zone that are not in the tallest stack...so if there was a box 11shu and a stack 1shu then they would recieve 11*1 = 11 points
"All containers within the alliance's scoring zone will be worth one point EXCEPT the containers in the tallest stack"
Unread 11-01-2003, 00:16
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Well.. would this be in the best intrest of the team doing it.... because they still get 2X their opponents score in QP, so say they did manage a win with the opponents getting say -30 qp, well they would drop by 60 IF FIRST allowed negative QP scores to be applied....
that just hit me like a sack of dead drill motors....
<edit> shawn on re reading your post I realized I jsut restated what you said in a way. red would still win.. but the real winner would be blue (see shawn's post) </edit>
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 11-01-2003, 00:19
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
red 16 +(2*60)=-104
Blue -60
Blue wins
Sort of correct. Red wins, but blue gets more Qualifying Points
Unread 11-01-2003, 00:20
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
Rookie Year: 1998
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
first of all, i haven't seen ya post in a while, Joe! it finally feels like a FIRST season again =-]
just a quick reason why this wouldn't be a good strat at all...
the QP for Joe's scenario would be as follows:
blue (the loser) of course would get -60 QP
red (the winner) would get 16 + 2*(-60) = -104 QP
the winning team is getting the lower QP!!!
the really needs to be addressed...
maybe the height of a robot-held stack should be measured from the lowest point in the stack... or maybe the multiplier stack height can never be higher than the number of bins in the stack...
something needs to be changed, that's for sure
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
  #15   Spotlight this post!
Unread 11-01-2003, 00:27
JTH JTH is offline
That's what I thought until Jacqui corrected me.
The original SC8 stated
All containers in the tallest stack located in the scoring zone (the “multiplier stack”)
are worth zero points. Containers in additional stacks of the same height will be
scored normally;
but, in order to fit with the original hint equation of "y=ax^2+bx+c", Team Update 1 changed it. That statement now reads
The height of the tallest stack located in the scoring zone (the “multiplier stack”),
measured in whole Stack Height Units (as defined in SC9) is subtracted from the total
number of containers to establish the “base score.” Containers in additional stacks of the
same height will be scored normally;
The original rule would have meant that a team could give the opposing team a huge multiplier. With the updated rule, because of the inverted parabolic scoring, we are seeing that teams can give penalties.
Powerbook update? evulish Chit-Chat 1 01-08-2003 18:48
Will There Ever Be Negative Scores? Joe Matt General Forum 30 18-01-2003 17:15
Stop Posting About Negative Scores Adam Y. General Forum 25 13-01-2003 15:44
Rules Clarification in Team Update #1 dlavery General Forum 8 08-01-2003 12:36
Why is'nt FIRST publishing scores? Ben Mitchell General Forum 7 15-03-2002 14:38
