Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Unread 11-01-2003, 19:07
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Helical gears that come with new drill motor
The kit comes with those helical gears that have 1/16" wide keyway and the 5/8" shaft with 1/8" wide keyway. I see the key stock for this application. Is this key stock good enough to hold these helical gears in place on the 5/8" shafts, or do I need to use a collar or something else to prevent the gears from sliding axially along the shafts?
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
