Knobby Tires
Does anyone have a good source for knobby pneumatic tires and wheel asseblies they'd be willing to share? Thanks! J#
We won a truck pull using the 4" hubs and grippy pneumatic tires provided by Skyway Tuff Wheels. Here's a picture:
-Kevin |
Thank you!
we also used skyway pneumatic wheels. They have INCREDIBLE traction on the mesh and HDPE, even with a simple drill tranny. On the mesh, I was pushing against the bot as hard as I could, and it didnt even know I was there. On the HDPE, again it pushed me off easily(I was not standing on the HDPE either) it has about 1000x the traction of the horrible stock wheels that came in the kit. I would definitely check them out. Here is a pic:
Can someone tell me really soon what the size of those tires are? Thanks.
the diameter of the wheel that we used, inclusing the hub is approximately 8"
Hmmmm, I wonder what those are wanted for
Anyways, Ill see what I can find out tonight P.S. I meant including thats what happens when ya dont use spellcheckCory |
#10
I found the specs for these wheels last night. They are 4" skyway pneumatic hubs.(Don't know the model #) along with 200x50 Cheng shin(chen shing?) pneumatic tires. If anyone needs more info, PM me.
Cory |
#11
Here are some part numbers:
9" x 2" Pneumatic Universal with 5/8" x 3/16" Keyway - WHL428 9" x 2" Pneumatic Universal with 3/4" x 3/16" Keyway - WHL424 9" x 2" Pneumatic Universal with 1/2" Precision Bearing- WHL414 Call Skyway @ (800)332-3357 to confirm the above info before ordering. There are also 9" x 3" versions available. 9" x 2" keyway wheels are $18.31 each 9" x 3" bearing wheels are $17.40 each |
#12
I just looked at the tires and they're labeled "Promo Durotrap" the size is "3.00-4". They're 10" in diameter. They're a very sticky compound (less silica, more natural rubber). As I mentioned, we got them directly from Skyway with our 4" hubs. -Kevin |
#13
How do they handle the ramp and HDPE?
#14
Skyway has either discontinued the pneumatic wheel line, or they just took them off their website. Does anyone have a catalog in pdf form?
#15
As stated above:Quote:
| Wheel wear??? 6" Pneumatic tires??? | Scott358 | Technical Discussion | 11 | 29-03-2003 13:35 |
| How good are your tires?? | com | General Forum | 44 | 29-01-2003 15:38 |
| Tires & Mechanisms | tenfour | General Forum | 2 | 27-01-2003 03:00 |
| Tread of tires!!!!!!!!!!!!!!!!!!!!!!! | geo | Technical Discussion | 1 | 05-02-2002 10:14 |
| Tread for tires! | geo | Technical Discussion | 2 | 04-02-2002 18:31 |
