Go to Post quite simply, not putting our best foot forward leaves us open to shooting ourselves in the foot. - Jessica Boucher [more]
Unread 12-01-2003, 21:51
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Question Drill Mount Suggestions?
Hey,
Four our drive train we have decided to use both the CIM and the Drill motor, however we've decided we'd rather just use the motor and not the included gear box. Does anyone have any good ideas that they are/have implemented on a mounting syustem for just the motor part of the 1/2" drill motor? Thanks.
-Rc
Unread 12-01-2003, 22:28
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
Rookie Year: 2000
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
gear boxs
Are you going to make your own custom made gear boxs??
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 12-01-2003, 23:04
Parks Parks is offline
Parks is an unknown quantity at this point
CIM and Drill
We have used these two motors together before and you cannot use the gear boxes they give you, obviously. Last year we just made our own gear box to match the RPMs and plan to do the same again this year.
Andrew Parks
CrescentSchool Robotics
Co-Construction Head and Driver
Team 610
2002 Regional Champs
2002 Engineering Inspiration
2003 Regional Chairman's Award
Unread 12-01-2003, 23:57
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
there's a white paper (maybe two) on combining these motors easily...
check out the white papers section for more info
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 13-01-2003, 00:09
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
there is no easy way to join the two....unless you don't care about how long your bosch motors last
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 13-01-2003, 00:14
AKA: Adriana
Rookie Year: 2000
That is what we did. We have a 2 speed transmission, and we used both motors and just made a custom made gear box for em.
Unread 13-01-2003, 00:21
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
you say u have a 2 speed tranny. can it switch gears reomtely on the fly? if so how do you acheive this?
1139 Alumni
Jeremy_Mc's Avatar
GitHubber
i think "easily" was taken out of context...
i meant it wouldn't take a lot of manpower...one whitepaper tells you how without having to have a fancy machine shop.
*jeremy
Unread 13-01-2003, 00:23
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Just an idea
We are trying to do the same thing: use the drill motor w/o the gearbox.
I think that Ryan's original question is concerning just how do we mount this drill motor if we are not using the gearbox... it's not very straightforward.
I see two options:
1. Use the two holes on the output face of the motor as pilot holes for a #10-32 or M5x0.7 tapped hole. If you were to do this, you would either need to use a metal forming tap instead of a cutting tap. Or, you just need to put grease on your cutting tap and go slowly through the hole... bit by bit... wiping off the grease and metal pieces for each turn or so... then putting grease back on the tap before cutting again.
The whole point of being careful, of course, is to not get metal shavings in the drill. Since the drill motor is worth $23, it's worth taking your time to do this.
2. Use the holes on the side of the motor. The same care would be needed when you tap these holes also, and they are in a non-convenient position. You would have to make a bracket (or 2) to get the motor mated into the gearbox, and that is kind of a waste. Also I don't see a good way to insure the motor's position when doing this.
I suggest option 1. We have not tried it yet, but we probably will within a few days. I'll post again to let you know how it goes.
Andy B.
Unread 13-01-2003, 00:28
AKA: Adriana
Rookie Year: 2000
It took us all 6 weeks last year. We almost did not pull it off. We switch gears using a servo. The only problem was that once we were in High Gear we could no longer switch down and a few of the dowel pins kept on falling out. So what we are going to try to do this season is get rid of the servos and see if we can switch gears using the pneumatics and tack weld the dowel pins in so they do not fly out.
Unread 13-01-2003, 00:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
If you are going to use a servo to switch the drills, make sure that you have a strong interface between the servo arm and the shifting ring. Last year, we had problems when we just used stiff wire to connect the two. Basically, it could only push the arm into the neutral position before deforming. After we used a piece of metal to connect the two, everything worked fine.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 13-01-2003, 09:09
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
Andy you got it more or less, I've already designed the gearbox for coupling the two to a common output, that wasnt the problem. My problem was actually mounting the drill motor without the front gearbox. If you can relay how the best way you found to do this after you try it, it would be greatly appreciated.
My white paper on our gearbox will come eventually, but not untill after 6 weeks
-Rc
-One day, I too will be a moderator on these boards......
Unread 15-01-2003, 09:52
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
we combined both the chiphua motor and last years drills together, they worked ok
it was kinda sketchy at first, but then it was ok...
bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 15-01-2003, 21:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Hint #1: Look carefully at the front of the Bosch motor, then examine the plastic motor retainer on the back of the stock Bosch gearbox. Notice the two round holes in the motor that fit over the two round pins on the gearbox, which prevent the motor from rotating when it is applying torque.
Hint #2: One the front and back of the Bosch motor, there are two ~1/4" square indentations, spaced 180 degrees apart. Seems like they are perfectly located for alignment/retention locks, doesn't it?
Hint #3: Take a look at how the hold-down strap for your car battery works.
We are also going for the dual-motor, dual-speed transmission, updating our design from last year. Throwing away the Bosch gearbox, and just using the motor directly into the transmission saves about 2 pounds per side of the robot.
-dave
Steal from the best, and then invent the rest!
  #15   Spotlight this post!
Unread 30-01-2003, 00:01
Rookie Year: 1998
drill motor mounted successfully
OK... we are in the final assembly of our gearboxes and we have had some success.
We took the drill motors and tapped the two holes on the face of the motor for a M5x0.7 screw.
Beginning with a regular tap dipped in grease, we started into the hole. Then, after a few turns to get the threads started, we pulled out that tap and began with another tap that had the point ground off of it (again, with grease). Using this tap, we threaded the hole deeper and got some pretty good threads on it.
The grease is used to grab the metal shavings when cutting the threads.
The motors were mounted into our gearbox and the threads seem to hold... we are not tightening the screws down too tight quite yet, though.
Also, we did this upside down. Clark and Kyle Gilbert performed this procedure... they may have more comments.
Andy B.
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Drill Motor Mount Experence ROB at RAGE Motors 3 04-02-2003 22:57
Drill motor suggestions... team222badbrad Motors 5 27-01-2003 09:59
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
