Go to Post Give us the e-mail address of these folks to send them a barrage of support letters for your students? - sanddrag [more]
Unread 13-01-2003, 08:16
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Helical Gears Gear Ratio
If we run the drill motors at 450RPM and put the kit together like the blowout on usfirst. Do the helical gears change the rpm at the wheels, or do we still have 450 rpm? What would be the gear ratio for the helical gears?
Unread 13-01-2003, 09:07
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
One gear is 1" and the other is 2" so you will have a 2:1 gear ratio with the helical gears.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 17-01-2003, 16:31
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Would it make a difference that the 2 helical's are set up like a worm gear speed reducer?
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-01-2003, 17:08
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
Team Role: Teacher
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
you really should do ratios based on teeth.
Each gear has a tooth count stamped on it. I think it is 24 and 48, the gear ratio is still 1:2 or 2:1 depend on which gear is the drive and which gear is driven.
Here is an excellent Gear ratio spread sheet that I got from another team on Long Island in New York.
It was created by Frank Saladino - Team 353 - www.pobots.com
It has been a very valuable tool for our team. (yes I know this is a bit off topic for helical gears, but you'll love it when you see it) :-)
~ Mr. Buonomo, Team 871
Unread 22-01-2003, 17:33
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
With the stock 9" wheels and the 2/1 reduction of the stock helical gearbox supplied in the kit, the drill motor will push your robot at 8.8'/sec. in low gear. This is pretty fast. ( In high gear, your speed will be 29'/sec!!!)
It appears that you can swap the 24 tooth gear for a 36 tooth gear, reducing your speed to 5.9'/sec, much more manageable. The 36 tooth gear has a pitch diameter 1" larger than the stock 24 tooth gear, so you will need to slide the plastic drill motor shaft bearing blocks 1/2" farther away from the large gear. If you file out the end of the plastic holder on the gearbox end plates, you should be able to do this. You can then drill new 1/4" locating holes through the side plates to hold everything in the new position. When we receive our new gears and have made this modification, I will post some photos.
Note that MSC does not carry this size of gear. You can get it from any BostonGear distributor.
Unread 23-01-2003, 17:05
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Rather than changing the gears, you could cut down the rubber on the stock 9 inch wheels. Reducing them to 6 3/4 inches will reduce the speed to about 6.6 ft./sec. It also reduces rather than increases the weight.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-01-2003, 17:07
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
5mph is fast??? Which is what I calulated as the speed of the robot with first's configuation. I'm really confused with all these units.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 23-01-2003, 17:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
generally, when speaking about robots, we use feet per second(fps) and not mph =)
5.5fps is not very fast... for low gear it is, but as a top speed it is not
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2003, 17:13
Adam Y.'s Avatar
Adam Y.
no team (?????)
Ahhh 5mph is 7.335fps. Fast but still a whee bit slow.
Unread 23-01-2003, 17:22
Dick Linn's Avatar
no team (Synergy)
Helical gears are not the same as a worm gear. Helical gears are like straight gears, it's just that there are right- and left-hand twists. Depending on the mix of twists, the shafts will either end up being parallel or, like this year's gearbox, at right angles.
A worm gear has the teeth parallel to the straighht gear and acts like a screw, so the pitch diameter is used
See this Georgia Tech mechanical engineering site for good basic inffo on gears, springs, motors and the like: http://www.srl.gatech.edu/education/...log/direct.htm
If you want a lot of info: http://www.bostongear.com/pdf/gear_theory.pdf
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-01-2003, 20:09
helical gear efficiency
Does anyone know the percent effiency of the helical gears that came with the kit? Does that effect speed , torque or both?
Unread 23-01-2003, 22:55
Dick Linn's Avatar
no team (Synergy)
Re: helical gear efficiency
Joe,
The helical gears are still efficient, although there is a limited contact point between 2 gears when the shafts are perpendicular. They should still more efficient than a worm gear. Just keep them lubricated. And make sure that when the spacer tubes and spring washers are installed, the gear is dead-center with no slop, but it spins easily. Your main concern with friction is that you will draw a lot more power, even if you don't see much reduction in speed. You can pop the breaker during a match or damage the motor from too much heat. Either one is worse than losing a bit of speed.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
helical gear info mickjagger Technical Discussion 4 02-02-2003 10:16
Helical gear help Gui Cavalcanti Technical Discussion 1 27-01-2003 16:20
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
confuzzling gear ratio definition.. wanna clear this one up? archiver 2001 5 23-06-2002 23:13
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
