I downloaded the 2.5alpha editor off of InnovationFirst.
However, it doesn't seem to be PBasic 2.5 I tried something like this: if vari > 25 then vari=30 If I am not mistaken, PBASIC 2.5 was supposed to allow commands like this. However, I still get "Expected a label" when I check syntax. Same thing with a multiline command. I "Expected a little different" from this editor. The program version under "Help>About" reads "2.0 Alpha (c) 1998-2003". This is a very recent release, but is it still not what we hoped for? Last edited by n[ate]vw : 13-01-2003 at 18:57. |
"Wisdom" From the Clueless
I tried exactly the same command and had no errors - are you sure you're using 2.5 code? When I drag FIRST's 2.5 code into a 2.0 editor, the commented line " ' {$PBASIC 2.5} " caused an error - could it be that you need that to jump into V. 2.5? I can't think of any reason why that would actually make any sort of difference, but it's worth a try if you don't have FIRST's commented initialization at the top of your code.
Did you add the {$PBASIC 2.5} directive?
*Sheepish grin* ....no.
Thanks alot! Update: I added the directive and now it works!! *now-excited grin* Last edited by n[ate]vw : 13-01-2003 at 20:24. |
| PBasic 2.5 vs. 2.0 | Anthony Kesich | Programming | 6 | 09-02-2003 22:06 |
| Broken PBASIC 2.5 Complier? | Mike Yan | Programming | 12 | 01-02-2003 09:11 |
| RoboEmu 1.09 (supports PBASIC 2.5) | rbayer | Programming | 22 | 21-01-2003 17:22 |
| PBASIC 2.5 Questions | Noah | Programming | 6 | 10-01-2003 19:26 |
| PBASIC 2.5 answer from Parallax | JasonS | Programming | 6 | 07-01-2003 19:21 |
