Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 13-01-2003, 20:27
JasonWestHigh JasonWestHigh is offline
#0648 (Quad CIty Elite)
JasonWestHigh is an unknown quantity at this point
programming
how does one go about changing forward to reverse in the edu robot ? Here is the code:
if rc_sw7 = 0 then skipOption7
p1_wheel = (((p1_wheel*154)/254)+100) max 254 'adjust wheel to 154-254
if drive_R < 127 then drive_R_reverse: 'is the right drive forward
drive_R = (drive_R - 127) min 0 'subract 127 to get the forward value
drive_R = (drive_R * p1_wheel)/254 'multiply by the wheel percentage
drive_R = (drive_R + 127) max 254 'add 127 back for proper output
goto drive_R_done: 'exit the drive right section
drive_R_reverse: 'the right drive is reverse
drive_R = (127 - drive_R) min 0 'invert drive-R to get a forward value
drive_R = (127 - drive_R) min 0 'invert drive_R back to normal
drive_R_done: 'drive_R section complete
if drive_L < 127 then drive_L_reverse: 'is the left drive forward
drive_L = (drive_L - 127) min 0 'subract 127 to get the forward value
drive_L = (drive_L * p1_wheel)/254 'multiply by the wheel percentage
drive_L = (drive_L + 127) max 254 'add 127 back for proper output
goto drive_L_done: 'exit the left right section
drive_L_reverse: 'the left drive is reverse
drive_L = (127 - drive_L) min 0 'invert drive-L to get a forward value
drive_L = (127 - drive_L) min 0 'invert drive_R back to normal
drive_L_done: 'drive_L section complete
skipOption7:
we changed the less-than signs to greater-than and still nothing happened.
Any ideas?
Unread 13-01-2003, 20:54
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
I think you're looking at the wrong chunk of code. This section (Option7) deals with the steering sensitivity. Option 6 is the one which deals with reversing the driving direction. To enable it, put a jumper on sw6.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
