Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Unread 13-01-2003, 22:02
greenz_gurl15's Avatar
greenz_gurl15 greenz_gurl15 is offline
#0812 (Midnight Mechanics)
Team Role: Student
greenz_gurl15 is an unknown quantity at this point
Send a message via AIM to greenz_gurl15
Track Drive
My team is discussing the use of a track-drive (something similar to tank drives). The problem we are running into is that we aren't sure what type of tracks to use or how to obtain them. Do you know how to do this or have any of you had previous experience with track-dribves? And if you remember any robots from the past that had track drives, please let me know. And if your team has worked with track drives in previous year, please let me know, also. It will be of great help! Thanks in advance.
-Hue
Team 812, The Midnight Mehanics
2004 National Engineering Inspiration Award
Unread 13-01-2003, 23:30
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
My best suggestion to you is to go up to the "Quick Search" box in the upper right and type in something like "treads" or "traction material" and hit search. These topics have come up many, many times in the past. There's lots of information sitting in these boards, and you'll get it a lot faster too.
Track drives can be great for traction, but there are several problems that need to be addressed/considered when designing one:
1. Weight Distribution: The track is pretty much useless unless there are "rollers" that apply pressure to the track. Some teams have let their treads glide accross a smooth surface, like Delrin, so that the surface applies all the pressure to the treads (and the wheels don't make contact with the ground). Team 92 is one example of this.
2. Traction/Turning: There is such a thing as too much traction. When turning tank-style, the treads have to "slip" accross the carpet or bad things can happen. One way of getting around this problem that we implemented last year (that we borrowed from another team) was using a caster attached to a pneumatic cylinder. The caster would be lowered to raise the front half of our robot, allowing it to turn easier.
Some have used Brecoflex belts for treads.
Example: http://www.chiefdelphi.com/forums/at...=&postid=90078
The best moments of our lives fall in two categories: those that did happen and those that did not.
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
