Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 14-01-2003, 10:59
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Help - objects won't move in Max
I have a strange problem. I cannot move the last few objects added to my scene. They're automatically created in the center, rather than where I click my mouse. I can resize & rotate, but not move. I checked to make sure the object & layer weren't frozen & it wasn't locked in hierarchies.
The other objects can be moved.
Any suggestions?
Unread 14-01-2003, 13:08
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
the only suggestion i can make is to upload the file and let people see it, cause it could be a problem specific to your computer. what OS are you running?
Where has all the fun gone?
Unread 14-01-2003, 13:10
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Is it parameter wired or controlled in some way. Upload it and we'll see.
Unread 14-01-2003, 14:06
AKA: Kevin Thorp
Rookie Year: 1998
Here's the file with the movable objects deleted (I didn't want to give away our story ).
For some reason every new object is locked in position.
Unread 14-01-2003, 15:41
Trashed20's Avatar
i think its missing something, like a file
Unread 14-01-2003, 16:04
AKA: Kevin Thorp
Rookie Year: 1998
Yeah - I've tried twice to attach a file. I'll try again. It seems simple enough: "Attach File", "Browse" & select the file. I select my zip file (only 19k) then it's lost when I press "Submit Reply".
Unread 14-01-2003, 17:50
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
In the Motion panel, under Assign Controller, your system has assigned a Path Constraint to the object's Position without a defined path, which is an error, so they don't move. All you need to do is change the Positionath Constraint back to Position XYZ.
Unread 28-01-2003, 12:49
AKA: Kevin Thorp
Rookie Year: 1998
That did the trick. Thanks Suneet!
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
