Go to Post Somewhere in New Hampshire at this very moment , the GDC is redesigning the game. - Whippet [more]
Unread 14-01-2003, 16:54
Redmen Redmen is offline
Redmen is an unknown quantity at this point
PBasic Help
Hey I need a little help. I’ve worked a little bit with PBasic but whenever I try and write a code for what I’m doing it doesn’t seem to work. I was just wondering if anyone could lend me his or her idea on how to generate the code. What I want to do is when you, for example, hit the trigger button on joystick 1 it performs an operation of opening and closing two different switches which would control a set of cylinders. I would like one button to cause a set of cylinders to close an arm and then cause a different set on relay 2 to push them up. In reality control two relays on one joystick button, which intern causes one to open and then the other to in a set of steps. If any one could please lend me some idea of an operation to do this it would be very much appreciated.
~Ferret
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
