Can anyone tell me what the optical sensor returns to the RC in terms of a number (i.e. if the optical sensor sees white, what will it tell the brain?) |
![]() *jeremy |
Ergh.
Read my sig. There're two digital outputs (either 1 or 0) on the Banner Optical Sensor. When the sensor sees its reflection, one is high (on) and the other is low (off), and when the sensor is not seeing the reflection, the opposite is true, the one which was low is high, and the one which was high is low. |
Have it your way! (no supersizing though) :mad:
It depends which wire you use for the digital input (black or white).
If we supply 12V power to the sensor, then
What happens if we plug the sensor outputs to the robot controller's (RC) digital input? Couldn't the amount of current, and voltage going to the digital input blow up the circuits in the RC? I though we could only supply voltages in the range of zero to five volts. |
When the optical sensor "sees" something, it will connect the sensor wire to ground, not to +12V. You are correct to be careful about how much voltage you are pumping through the RC, but in this case you are safe. Likewise, when you wire up limit switches, etc, always connect them between ground (from the RC switch port) and the switch pin.
The 12V power source is for powering the light source on the optical sensor. None of it gets sent to the robot controller.
The robot input is actually a positive lead that supplies 5V @ a maximum of 10mA. This is far too little to power the sensor. |
| optical sensors | majormusic2005 | Electrical | 5 | 11-03-2003 21:32 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| optical sensors | great_one411 | General Forum | 1 | 15-02-2003 19:54 |
| optical sensors | majormusic2005 | General Forum | 1 | 28-01-2003 20:37 |
| OPTICAL SENSORS??????????????????? | NM_programming | Technical Discussion | 2 | 13-01-2002 17:41 |
