Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 14-01-2003, 22:23
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Question Where to get shaft encoders
I have been trying to make some, and frankly. I would rather puchase shaft encoders from a supplier. I have looked on digi-key and future. But is there anywhere else I can get it?
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
Unread 14-01-2003, 22:25
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
If digikey and future don't carry them, they're not going to be legal to use on your robot.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 15-01-2003, 13:43
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Where to get shaft encoders
The answer of course is to make them...and since you probably have access to all the internals of your transmission and drive-train....you can place the sensor anywhere in there and measure as accurately as you want! (might I suggest hall effect...it is very simple and straight forward)
Good luck,
-Quentin
Live free or die....
Unread 15-01-2003, 16:24
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
Page 830 in digikey catalog http://dkc3.digikey.com/PDF/T031/SectG.pdf
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 16-01-2003, 01:43
D.Viddy's Avatar
AKA: Dylan Vester
Thank you very much
That's exactly what I needed. Big help!
Unread 16-01-2003, 21:42
D. Gregory's Avatar
D. Gregory D. Gregory is offline
FIRST Junkie
no team (UHS Wolfpack)
D. Gregory is an unknown quantity at this point
Send a message via ICQ to D. Gregory Send a message via MSN to D. Gregory
Does a shaft encoder measure rpm? If it doesn't, what does.
Duct tape is the force that holds the universe together. Everywhere except FIRST that is.
Unread 17-01-2003, 00:01
#0811 (A.R.C.)
A shaft encoder generally measures the amount of rotation of a shaft.....but if you look at the amount of rotation with respect to time, you essily have RPM.
Unread 17-01-2003, 00:21
D. Gregory's Avatar
FIRST Junkie
So, is that what I would use if I wanted to prgram a dead reckoner using rpm. I.e. all motors turn 3000 revs foward, stop, left side 1000 rev foward-right side 1000 rev backwards, stop, all motors turn 10000 rpm foward.
Unread 17-01-2003, 00:39
D.Viddy's Avatar
AKA: Dylan Vester
Truth about shaft encoders
The way shaft encoders really work is with ticks. They send ons and offs to the control system, and every tick (or on) that is sent to the RC would be a certain angle. So if an encoder could send 36 ticks per revolution then you would no that every tick recieved is 10 degrees. So if you could how many ticks have gone by you could easily know when one revolution has occured.
Unread 17-01-2003, 01:38
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Digikey does sell some Rotary Optical Encoders. These are single-piece enocders for motor-monitoring applications. Up to 3,000 RPM. You won't be able to use them on the robot controller though, as it is far too slow. You'll need to feed the data to a separate microprocessor and use that to count shaft rotations, then feed the data to the robot controller.
Be careful when devising a way to mount them. This Bournes Data Sheet says it doesn't tolerate much axial stress. You might snap it off.
You could contact Bournes and see if they'll send you a sample. You'll still have to include the $50 price tage in your $200 total (that eats up $100 there -- one for each side), but it'll possibly save you some money.
Basically, what I'm trying to say is... this is an option, but it's not for the inexperienced.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 17-01-2003, 01:46
D. Gregory's Avatar
FIRST Junkie
I can't really afford that, I'm on a tight budget. Is there any easier and cheaper way to do dead reckoning? Time perhaps?
Unread 17-01-2003, 07:14
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
It looks alot easier to make one than to buy it. Btw how are you trying to make it.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 17-01-2003, 09:38
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
mechanical shaft encoders
Digi-key has some mechanical shaft encoders that are only a few bucks each. Has anyone used one of these?
They're in the bottom right-hand section of the catalog page. There is one that has a 4 bit gray code output. Does it function like 4 switch inputs to the controller? I'm assuming its a passive device.
If thats how it works, then you should be able to grab the nibble on each loop and use it to figure out how far it went during the cycle. As long as your wheel doesn't turn more than 16 times between samplings it would be fine.
They don't have the hex output version, only the 4-bit gray code. Its defined in the data sheets so you can convert the gray to hex in code.
Using Digi-Key Shaft Encoders D.Viddy Programming 45 02-01-2005 20:11
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Motor coupling archiver 2001 19 23-06-2002 23:35
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
