speed controllers & circuit breakers
I've heard that the speed controllers require a 40 amp circuity breaker. Is that true? Can we use 30 amps instead? If you can only use 40, that'd limit our # of speed controllers to 4, because you can only use 4 40amp circuit breakers. Thanks a lot.
| initialization program and speed controllers | rosebud | Programming | 15 | 05-10-2004 03:35 |
| speed controllers | archiver | 2000 | 5 | 24-06-2002 00:19 |
| circuit breakers.... | archiver | 2001 | 2 | 23-06-2002 23:58 |
| Circuit breakers | archiver | 2000 | 8 | 23-06-2002 23:30 |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 11-02-2002 13:24 |
