Go to Post I am not a poofologist... - Greg Marra [more]
Unread 15-01-2003, 19:23
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
more on friction
keep in mind that Mu static is much higher than mu kinetic, so when experimenting try and push the assembly to when it just about moves, and make sure that the robot's drive assembly can exert that force, also the ramp could be interesting when the normal force also contributes to the friction, really straining your robot, and make sure that if the robot does stop on the ramp, that it can get moving again. there would be nothing more sad than a robot that makes it half way up, stops and rolls back down and has to try it again.
friction in this case is also dependent on how much carpet physically comes in contact with the wheel, the ridges in the wheel will cold fuse to the carpet, creating what we call friction, so the more reactive material in direct contact should effect performance, but my knowledge there is a bit shaky, so I'll bug my physics teacher to add another post.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Friction as a function of area rbayer General Forum 28 31-01-2003 07:28
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
Speed to Goal? Jim McGeehin General Forum 45 14-04-2002 10:06
Speed loss due to internal friction patrickrd Technical Discussion 1 23-01-2002 22:12
Tread or Wheels? Jordan A. Technical Discussion 28 10-01-2002 04:05
