Go to Post In my opinion, the right mix of student, mentor, and engineer involvement is when everyone gives it 100%. - Jack Jones [more]
Unread 15-01-2003, 20:14
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
TechnoKats Automated Test Drive Code
Once it gets approved, I've uploaded into the white papers section a fairly simple automated test code especially for use by teams less-experienced in software. It is based on the old default code though, so it will run on old robots (we've tested it on a 2000 controller and a 2003 controller) but will not work in this year's competition. You use the wheel on the joystick plugged into port 3 to control auto on or off. Obviously you will have to tweak the numbers to get your robot to run well, but the code is heavily commented, so you should be able to find your way around
Hopefully I can upload a 2003-compliant version pretty soon...
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
