Go to Post Our robot name is currently "Subject to Change". - JesseK [more]
View Poll Results: Will your team run the drill motors with the pins in or with the pins out?
IN 16 40.00%
OUT 24 60.00%
Voters: 40. You may not vote on this poll
Unread 16-01-2003, 08:43
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Drill Motors: Pins IN or Pins OUT
IN OR OUT?!?!
Unread 16-01-2003, 08:49
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Unfortunately, it's not that easy. Do you want to coast after you return the joystick to neutral, or stop right away? If you want to coast, pins out. If you you want to stop (like you have brakes), pins in... Depends on your control strategy.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 16-01-2003, 14:32
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I should note that you can also control coasting/breaking ability with the Speed Controller. If you set the Speed Controller to the break setting, it will break you no matter if the pins are in or out of the gear box. If you set the Speed Controller to coast, it will coast if there are no pins in the gear box. If there are pins in the gear box, it will break.
As a word of advice, I'd say remove the pins and use the Speed Controllers if you want to break. The pins are just an extra item to break in the gear box when put under stress.
Matt
Unread 16-01-2003, 14:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
this was mentioned before, but I'll say it again. Keeo in mind that id you are on the top of the ramp and the match ends. If you have the pins out, and someone was pushing you at the end, you may roll backwards right into your stack of boxes.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2003, 16:31
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Matt
How do you set a Speed Controller to break or coast?
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 17-01-2003, 09:04
Unsung FIRST Hero
Rookie Year: 1998
There's a jumper that can be set on the speed controller. It's in one of the corners (the lower left hand if you look at it from where you can read the InnovationFIRST logo).
Matt
Unread 23-01-2003, 21:53
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
What does the jumper do?
I know what and where the jumper is, but what exactly does it do? What advantages does it have over leaving the pins in?
-Matt Durstenfeld
Unread 24-01-2003, 08:57
Unsung FIRST Hero
Rookie Year: 1998
The coast/brake jumper on the speed controller works by either closing or opening the circuit that the motor is on. When set to coast and there is no input to the motor (ie, an input to the speed controller of 127), the speed controller open circuits the motor so that it can spin freely. When set to brake and there is no input to the motor, the speed controller closes the circuit to the motor. This causes there to be resistance to the back driving of the motor. The speed controller absorbs the created force and dissipates it as heat.
The main difference between the speed controller and the pins is that the speed controller will engage immediately whereas there's still a bit of a turn (though very slight) with the pins. Also, I've seen more trouble with gear boxes breaking (ie the pins take too much stress and break) than with the speed controllers going. I'd trust the speed controllers over the pins.
Matt
Unread 24-01-2003, 12:52
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
Rookie Year: 1999
caffel is an unknown quantity at this point
removing the pins creates another problem
If you just take out the pins, there will be a nasty lash situation between the two rotating parts that are still there.
Last year, we had some success with using red RTV to fill in the gap. To do that, however, we discarded the black ring which surrounds the pins and replaced it with a ring that would contain the RTV and rotate along with this new 'coupling'
This year that ring is not removeable.
Ideas appreciated.
Charlie Affel,
Mentor 423
Unread 24-01-2003, 19:34
hi_im_sean hi_im_sean is offline
hi_im_sean is an unknown quantity at this point
if you leave the pins in, exactly how easy do they break under heavy braking. also would it be safe to punt the robot in reverse for a brief second to stop it.
remember we are talking about drill motors here.
Unread 26-01-2003, 20:27
Matt D's Avatar
college time!
A few more questions...
I have a few more questions about how the jumper is used. The current jumper is attached to pins B and C. Is this the coast configuration or the brake configuration? How do you configure it for the opposite, remove jumper? Attach to A and B? Attach to A and C?
-Matt Durstenfeld
Unread 27-01-2003, 08:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I assume you are talking about the locking pawl in the drill transmission. Many teams leave this part in thinking that the braking (locking the output shaft) is a good thing. If your travel speed is fairly high, when you remove drive from the motor and the locking mechanism clicks in, damage to the transmission is almost assured. Remember the locking mechanism was designed to lock the shaft to allow turning screws while in the screwdriver mode of the clutch. With the new motor/transmission we have this year, that may have been addressed differently by the manufacturer.
Brake mode on the speed controller causes both the low side FETs pairs to turn on producing a dead short across the motor. As the motor is being turned by the momentum of the robot, the motor acts like a generator and dumps all of it's current into the dead short of the speed controller. (In practice the load is the resistance of the FETs in "ON" plus the resistance of the wire between the motor and the controller, or roughly .1 to .3 ohms.) In coast mode, all FETs are turned off and the motor has no electrical load.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-01-2003, 10:57
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
I would agree with matt and say out (since I already took the pins out this year) and I just wanted to comment on the getting pushed off the top statement that if you are getting pushed off the top with out the pins your wheels will turn but won;t you be pushing back anyway?.....and also if someone has the power to push you off the top would you rather roll back or just sit there getting pushed on ........remeber it is usally the case that the less time that your robot has in contact with another robot the less chance something will break.
I also think that if someone can't stop their robot from rolling down the hill to hit one of therir stacks then they have more problems then the pins
Unread 27-01-2003, 13:49
Unsung FIRST Hero
Rookie Year: 1998
If I remember correctly, there is no A label near the jumper. Instead, set the jumper to the B side for brake and the C side for coast. In general, if it's not working the way you expect, just swap the jumper. There shouldn't be any harm done to the speed controller.
Matt
  #15   Spotlight this post!
Unread 27-01-2003, 18:05
AKA: Charlie Affel
FRC #0423
Rookie Year: 1999
pins out, coupling parts break?
To Al S.
Assume that you remove the pins, what do you think about the issue of lash between the motor side of the clutch/coupling (one side of the pin) and the output side (the other side of the pin). There will be over 10 degrees of free play.
When the motor starts or reverses, there will be a hard collison betwen these two parts.
Its kind of like a misalignment coupling but with the rubber star shaped insert left out.
Charlie Affel, 487
Charlie Affel,
Mentor 423
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
