Go to Post This is definitely the best FRC parody of an FRC parody I have seen. - Jared Russell [more]
Unread 16-01-2003, 13:10
Kevin N Kevin N is offline
#0451 (The Cat Attack)
Kevin N is an unknown quantity at this point
Bosch Gearbox. . . High or Low Gear
Does anyone have any advice on which gear(high or low) you should design a drive system? We plan on using 1 speed. I do realize the low gear is more efficient than the high gear(97% vs. 92%) but reading one of the "White Papers " on last year's gear box, there was procedure describing a spacer ring that could be placed in the gear box locking it in high gear. Does the same concept hold true for this years gearbox? If so, I guess its. . . high gear?
Unread 16-01-2003, 13:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
use it in low gear, it will provide more torque, and still provide decent speed, especially if you gear it well using sprockets, gears, whatever.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2003, 14:29
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
we're using high gear and gearing it down considerably...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
low gear vs high gear archiver 2000 1 23-06-2002 23:07
KSC Results archiver 2000 2 23-06-2002 22:19
