Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 17-01-2003, 22:08
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Question Does the line continue up the ramp?
Does the white line continue up the ramp?
The thread below makes mention of the supports in line with the tape being reflective. I just want a little more clarification.
http://www.chiefdelphi.com/forums/sh...tape+up +ramp
Unread 17-01-2003, 22:12
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
no, the line does not continue up the ramp.
~Adam
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
No
The line DOES NOT continue up the ramp.
edit- Adam beat me... /edit
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 17-01-2003, 22:46
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
The line itself does not continue, but I believe that one of the ramp supports lines up directly with the white line.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 18-01-2003, 00:48
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
TWO of the ramp supports line up with the two lines. These supports are not painted white, but they are aluminum, and should be easily detected by your optical sensors.
One twist -- which I haven't had a chance to play around with -- is the fact that over this aluminum support is the wire mesh. This will PROBABLY cause the signal from the support to flicker as you go up the ramp.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 18-01-2003, 18:07
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Does the line continue up the ramp?
The tape is not the reflective tape used for marking the containers for human player use. From "the Game" section 10.4 "If tape is used to mark the white tapelines that run from inside of the starting areas to the base of the ramps, it will be Shurtape, PC-628 Premium Grade Tape, Vinyl Coated Cloth, White, 2” wide. If you cannot find this tape, go to:
www.tapemonster.com.
If FIRST decides to use paint or some other means to indicate these paths, you will be informed in a
Team Update."
While it is true that the wire mesh is copper flashed, I would not depend on the copper remaining for an entire competition. I expect the mesh to become worn and polished.
Al
WB9UVJ
www.wildstang.org
________________________
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Q&A Discuss: Does the line continue up the ramp? CD47-Bot Extra Discussion 5 18-01-2003 01:01
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
