Go to Post Understand that not only can you learn from other experienced engineers, but also mechanics, farmers, and craftsmen. - Andy Baker [more]
Unread 18-01-2003, 16:25
Jim Harbison Jim Harbison is offline
#0484 (lron lammas)
Jim Harbison is an unknown quantity at this point
Lightbulb Fixing the drill motor you dropped part 2
To retain the wires and prevent fatigue failures from handling ........the wires will be captured in and the brush holder will be protected using a compressiom band ie a piece of bike inner tube or those phat rubber bands they put on brockli(sp).........talk to your produce guy they are cool cause they come in bright colors.So using either band stretch it over the brush holders and add a second one for additional protection.DO NOT block the fan PLEEEEEEEEEEEEEEEZZZEEEEEEEE.Apply power to the motor to insure it running and race ready.
When you do the next motor preform the wire before you solder them .
Jim
Unread 18-01-2003, 16:42
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
http://www.chiefdelphi.com/forums/sh...threadid=16675
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 24-01-2003, 12:34
Dr.Bot
Posts: n/a
No system is fool proof, because fools are so clever.
I mounted the motor and had it sitting in the mount on the bench so it wouldn't role.
A team member walked into the room and his b.ack pack snagged the entire assembly and knocked it to the floor - no damage fortunatley, Though I did need to stop a mass assault on the clumsy oaf!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Fixing the drill motor you dropped Jim Harbison Motors 0 18-01-2003 16:14
