Go to Post Every robot is a key element to each victory, no matter how much or how little they help. - JosephC [more]
Unread 18-01-2003, 23:40
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Using Digi-Key Shaft Encoders
How would I go about programming one of these, and which one would be ideal for positioning a low speed (60 RPM) shaft? Any info is appriciated. Thanx.
Digi-Key Shaft Encoder Pages:
http://dkc3.digikey.com/PDF/T031/0830.pdf
http://dkc3.digikey.com/PDF/T031/0831.pdf
http://dkc3.digikey.com/PDF/T031/0832.pdf
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Where to get shaft encoders D.Viddy Programming 12 17-01-2003 09:38
Motor coupling archiver 2001 19 23-06-2002 23:35
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
