OCCRA
Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
CD-Media
Unread 10-19-2018, 07:59 AM
TBKahouna TBKahouna is offline
Strategy and Systems Engineering
AKA: Ronald (Ron) Houde
FRC #3986 (Express-O)
Rookie Year: 2018
TBKahouna has a spectacular aura aboutTBKahouna has a spectacular aura aboutTBKahouna has a spectacular aura about
pic: Cabon Fiber Reinforced Nylon Filament 3d Printed Parts - FRC 3986
Unread 10-19-2018, 08:00 AM
Thequackmaster's Avatar
Thequackmaster Thequackmaster is offline
FRC #0107 (Team R.O.B.O.T.I.C.S)
Team Role: Electrical
Rookie Year: 2017
Thequackmaster is an unknown quantity at this point
Re: pic: Cabon Fiber Reinforced Nylon Filament 3d Printed Parts - FRC 3986
Is it nylon X?
Unread 10-19-2018, 11:51 AM
half_ton_hero half_ton_hero is offline
FRC #6517
half_ton_hero is an unknown quantity at this point
That is awesome! So many questions! Do you have issues with first layer adhesion or the Nylon delaminating? Do you use the default Nylon profile for the machine? Do you have the Prusa MK3 in an enclosure to keep the ambient temperature up? We have been looking to do something similar on our two Prusa MK3s, but have heard Nylon can be tricky. Thanks!
Unread 10-25-2018, 11:05 AM
chrisrin chrisrin is online now
FRC #4915 (Spartronics)
Rookie Year: 2016
chrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to behold
Nice! Has anyone by chance tested this material vs. Markforged Onyx in the context of FRC applications? Seems like it should be similar.
Unread 10-29-2018, 05:06 PM
hrench's Avatar
hrench hrench is offline
mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant futurehrench has a brilliant future
So I just got a Prusa and I also ordered the carbon-fiber filament that they sell.
So far I've only bought the stock brass nozzle, so I need different one to print the carbon fiber.
But the book says I just need the hardened steel nozzle.
So tell me, the ruby nozzle--is that better? Do I need it?
Will I need to take it back off to print PLA etc?
Unread 10-29-2018, 07:33 PM
cadandcookies's Avatar
cadandcookies cadandcookies is offline
AKA: Nick Aarestad
FRC #2220 (Blue Twilight) & FTC 9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
The difference between the Ruby and a hardened steel nozzle is how much filament it can put through before needing to be replaced. A hardened steel nozzle will open up as the abrasive CF filament wears at it. This happens in a few kilos of material. The Ruby is more durable, and can basically handle as much abrasive filament as you can throw at it.
Last I checked, it would take ~4 steel nozzles to equal the cost of a Ruby. That might have changed, but that equated to ~16 kilos of material printed on the estimate of 4 kilos of CF filament wearing out a steel nozzle. You'll probably want to update those numbers with whatever the current prices are, and want to do your own research on how long it will take to wear out a steel nozzle. There are various estimates out there based on what kind of steel the nozzle is.
If you're planning on aggressively printing lots of parts, a Ruby nozzle is probably worth it. If it's not the primary use case for the printer, it may not be.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
grabcad | twitter | github
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16) -> FRC 2220 (18-??)
VEXU UMN (2015-17)
Volunteer since 2011
Unread 10-30-2018, 12:45 PM
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
Alumni
AKA: Dwight Howard, II
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is a splendid one to beholdDwight_2 is a splendid one to beholdDwight_2 is a splendid one to beholdDwight_2 is a splendid one to beholdDwight_2 is a splendid one to beholdDwight_2 is a splendid one to beholdDwight_2 is a splendid one to behold
This reminds me a lot of the oynx from the markFordged printers that my team uses, utmost the strongest prints I've ever seen and worked with. If teams have the money I really recommend this kind of print even if it's not used that often.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016)
Student team Co-Leader, Documentation Chair, Drive Team (2017)
2017 Lone Star Regional Winner
(3284, 5842, 6547)
Mentor iRam Robotics 7194 (2018)
"It Doesn't Get Easier. You Just Get Better."
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
