Go to Post The real world doesn't snap together easily. - Joe G. [more]
Unread 19-01-2003, 10:47
Morgoth Morgoth is offline
#0471 (Cybertigers)
Morgoth is an unknown quantity at this point
Whats wrong with this code?
This is my first year doing the programming and I am having trouble with if statements. I know C++, Javascript, regular BASIC but i can't figure out whats wrong with this.
if (p1_y > 135) then skip:
skip:
relay1_fwd = 1
I used "skip:" because if I just put relay1_fwd = 1 under then, it tells me that it expects a label or something directlyafter then. I have tried it with 135 < p1_y and that doesn't work either. I have verified that something is hooked up to relay1, so that isn't the problem. It compiles fine but when I put the y axis on port 1 to greater than 135 nothing happens. I know the joystick works because I have checked it using dashboard.
Also, does white space matter in PBASIC?
Thanks a lot
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
