Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Unread 19-01-2003, 13:03
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
Question Drill Motor
Hey guys I ran into a lil problem, Im using the Drill Motor and built in Trans. And I need to connect the 1/2 threaded drill shaft to a 5/8 keyed shaft. Im not 100% sure what parts ill need so if you guys could give me a lil help that would be great! Thanks Alot
"Who needs Battle Bots, Ive got US FIRST!!!"
Unread 19-01-2003, 13:11
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
They are all in the kit . . the 1" hex parts.
Theres one that screws onto the threaded drill tranny part, with a screw to hold it in place, theres a black connector to connect that to another hex shaft that has a bore on one side to accept a 5/8" keyed shaft.
Unread 19-01-2003, 13:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
In the kit there are 2 aluminum hex couplers that are 1/2 threaded on one side and 5/8 bore keyed on the other side. The threaded shaft will try to reverse out in one direction so I would pin it or JB weld it or both.
*edit - beat me to it Frank.
Unread 19-01-2003, 13:41
Thanks Alot
Hey I thanks a bunch, but one last thing, what is the size, shape, and color of theses parts Im looking for. You see some kids on the team have been fooling around and moved all the parts around the shop, so any discriptions or pictures of the parts would be very great. Thanks Again for all your help, and I really mean it!
Unread 19-01-2003, 13:44
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
The plastic pieces are black and the aluminum pieces are...metallic? gray? aluminumish?
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 19-01-2003, 18:04
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
You can see them here.
http://www.archergeeks1022.org/photo...off/index.html
Hope that helps.
P.S. You shouldn't need the JB weld if you use the two left hand screws. They are black cap head screw with lock tight on them (little blue drop) I believe they are 10-32's.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 19-01-2003, 18:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Thanks Alot
Its always a good idea to inventory everything when you get it, so you know what you have, and what you are missing. Don't let anyone play with things either, its a good way for them to break, or get lost. We are having this problem too...
Good Luck,
Cory
2001-2004: Team 100
2006-Present: Team 254
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
