Go to Post Right now that dream is sealed behind a few milimeters of plastic for most teams. - AllenGregoryIV [more]
Unread 19-01-2003, 14:03
trollin1st's Avatar
trollin1st trollin1st is offline
AKA: Janice Bourget
Team Role: Coach
Rookie Year: 1999
trollin1st is an unknown quantity at this point
Send a message via AIM to trollin1st
Trouble with drill moter assembly?
We built a prototype with the drive train assembly that FIRST supplied this year, we have found that the screws on the flexable coupler come loose, always...we also tried lock tight and it ended up stripping the inside of the coupler, since we found that alunminum and steel don't work well together with lock tight...does anyone have anyother suggestions or similar issues with this pre-built drive system??
To err is human, and to blame it on the computer is more so.
Unread 19-01-2003, 14:12
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Did you use the left-handed bolts that come with the motor mounts? They go through the black coupler and into the aluminum drill motor attachment. They are needed to hold it together.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 19-01-2003, 14:33
trollin1st's Avatar
AKA: Janice Bourget
Team Role: Coach
Rookie Year: 1999
Yes...it still came loose...I'm not sure why...
Unread 19-01-2003, 15:29
Hmm, that's odd. I wouldn't recommend using lock tight (is the brand Loctite?) though as it would be quite hard to remove the bolts if it is ever necessary. We haven't been able to test our drive system with the drill assemblies yet since we are waiting on some parts but I'll let you know how they work for us when we get to testing...
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
