Ok, I was looking at the spec pages for the FP and globe motors. I recall from past years, that these spec sheets have errors (it looks like they used the same file, and never fixed the errors)
First: Stall torque for the FP motor is listed as: 0.380 N-m (mili-NEWTON meters) What are they talking about? It must be N-m, not mN-m, because there would be no way you'd get 34.7 N-m with a 124:1 gearbox. Second: RPM for globe motor only: 97 RPM. Globe motor & gearbox, 87 RPM. Yet the torque goes from 30 oz-in to 150 in-lbs... something doesn't compute... I'll believe the other data that says that the motor-only gives around 11500 rpm. Obviously, most people on this board already realize these errors, because a lot of this data is in the white papers (from other sources, not FIRST) I guess I wanted to gripe, because not only do we get specs (finally) 2 WEEKS into the competition, but they're also so obviously wrong. Lesson to learn: always apply a "garbage" filter to any data you use, and ask the question "does this number make sense?" my $0.02 Simon |
| Signal specs for FIRST contorllers | Tim Skloss | Technical Discussion | 6 | 08-31-2003 06:30 PM |
| Digital inputs, bandwith, errors? | Micah Brodsky | Programming | 7 | 01-20-2003 04:08 PM |
| Q&A Discuss: Are specs available on the new motors/mounts? | CD47-Bot | Extra Discussion | 3 | 01-15-2003 07:39 PM |
| Looking for full playing field | archiver | 2001 | 1 | 06-24-2002 12:13 AM |
| Motor specs | kmcclary | Off-Season Events | 4 | 10-26-2001 10:41 PM |
