Muffin Fan wire 16vs.24
Why are we required to wire large muffin fans with 16 gauge when it comes wired with 24 gauge. Does this make sense? It's less than a half amp motor.
I would say that is a good question to ask on the FIRST forum -- if it hasn't already been asked. Be sure to search first.
Why is this an issue. The #16 is more robust and easier to crimp a push on to. The only serious reason would be for weight reduction.
I think the issue is that the fans are pre-wired, and it's more work to re-wire them with 16 gauge. I'd put this up to FIRST if you haven't already.
I always interpret FIRST's rules requiring wire many times the size of the wire going into the device to mean that FIRST is trying to make sure that if shorted (in a horrendous crash, that twists metal and rends 1/2" lexan), the wires are capable of drawing full 20 or more amperes through the related Spike or Victor, without getting hot - or even perspiring (much less 'glowing').
Eric R is always saying he just wants to make sure it's safe. A way to get around it is to mount the fan so close to its supply that the manufacturers lead wire is long enough. |
| Telephone wiring | Lisa Rodriguez | Chit-Chat | 4 | 18-06-2003 00:22 |
| Q&A Discuss: Ramp wire | CD47-Bot | Extra Discussion | 2 | 06-01-2003 20:57 |
| Drill Motor Connections | archiver | 2001 | 8 | 24-06-2002 00:49 |
| Motor wire sizes | Tim Skloss | Motors | 5 | 13-02-2002 07:44 |
| wire question | James Crivellone | Electrical | 1 | 13-02-2002 07:32 |
