Go to Post Can I help it if I check Chief Delphi before I look at the Team Updates? - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 20-01-2003, 17:46
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Hand Texturing
Are there any ways to texture a complex object like a human hand, wihout Unwrap UVW modifier?
To texture our model (made with box modeling) we've split it in top and bottom parts, and then painted a texture for each using Unwrap UVW with plalanar projection on both of them. The problem is that it is very difficult to match the textures on each side, which results in a noticeable seam along the edge. (see pictures)
//edit: seems like direct links do not work - instead, copy and paste them in browser's address line
split model http://www.eccentrix.com/members/z80180/hand4.jpg
bottom view http://www.eccentrix.com/members/z80180/hand1.jpg
top view http://www.eccentrix.com/members/z80180/hand2.jpg
seam http://www.eccentrix.com/members/z80180/hand3.jpg
Does anyone know of any easier ways to do this? The only solutions i see right now is either splitting the mesh in 6 parts (arm and 5 fingers) and using cylindrical projection for each, or using a separate 3d painting program (like ZBrush, DeepPaint3d, etc) to paint texture directly on the object.
Unread 20-01-2003, 18:51
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
the links don't work
1139 Alumni
Unread 20-01-2003, 19:02
Lev's Avatar
Lev Lev is offline
See the edit - they do not work when you click on them, but you can still see the images, if you just type the address in your browsers address line.
Unread 21-01-2003, 13:30
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
So, how did you model the hand? Can you post it?
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 21-01-2003, 23:27
Lev's Avatar
Lev Lev is offline
The model was made with standard meshsmooth box-modeling, similar to the claw tutorial in 3dsmax5 tutorial book. The difference was that instead of strating out from the palm, i've modeled the fingers first, then joined them and extruded the palm after. I can post a more detailed explanation if needed.
Unread 22-01-2003, 08:22
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
The only way you're going to get rid of the seam is to make sure the scans line up properly and then edit your verticies so that they make the textures meet at the proper points. You'll want to be sure that the textures themselves have the same tones and patterns on both sides- it looks like the back of the hand is a lot paler than the palm, so try fixing it in photoshop or rescan it first. Unless someone out there knows a better way, that is
Unread 22-01-2003, 15:21
Lev's Avatar
Lev Lev is offline
Thanks, that's exactly what i'm doing right now, but i'm still wondering if there is an easier way...
Unread 27-01-2003, 19:22
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Rookie Year: 2000
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
For those who dont know what he meant by Deep Paint 3D:
The best and fastest way to do proper texturing is with a program like Deep Paint 3D. I've seen it used and it's awesome. If your team has some bucks to put out for animation (or maybe your team's really really good at getting stuff donated) you can get a copy from them. Its almost like photoshop for 3D. You export your object to it, use brushes and everything in deep paint, it creates the texture map and exports it back to max. Really helpful.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 27-01-2003, 22:28
Lev's Avatar
Lev Lev is offline
The problem had been solved - without any additional software or techniques - just plain photoshopping... Now the two sides match almost perfectly. There are still many things that can be improved, like a detailed glossiness map, but we dont have much time for that.
here is what it looks like now:
http://www.eccentrix.com/members/z80180/hand.jpg
(again, copy and paste the link)
Unread 27-01-2003, 22:50
AKA: Jim Martz
Rookie Year: 2000
Ahhh, looks excellent!
Unread 27-01-2003, 23:41
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
You have no idea how creepy that looks.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 28-01-2003, 18:58
AKA: Jim Martz
Rookie Year: 2000
Naaahh..now if you used a particle system and some nice effects..and maybe some glowing, that made the hand seem like its summoning powers from beyond..then MAYBE it'll look creepy....
Unread 28-01-2003, 21:31
Lev's Avatar
Lev Lev is offline
There was no intention to make it creepy... I will be glad to hear ways to reduce the creepiness in it...
Unread 28-01-2003, 23:19
AKA: Jim Martz
Rookie Year: 2000
Isn't that a spinner somewhere...Juss change it from Creepiness 100 to 0....
...Then see if its animatable...
kay, sorry..Im done..its late, I'll post real suggestions tommarrow
