Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 20-01-2003, 21:16
David Bryan David Bryan is offline
#0818 (Steel Armadillo)
David Bryan is an unknown quantity at this point
Unhappy Autonomous Mode
Thanks to Ian Krieg for some help on this. I would still like to get more information:
My question:
Can you help us with the mode in the program in going from the Autonomous
>Mode to the operator mode. I assume there must be some code to allow the
>autonomous mode to run for the first 15 seconds, and then allow the
>operator interface code to proceed for the rest of the match.
Ian answered:
The new default code, which apparently requires a new beta of the
stamp software, defines extra bits in PB_Mode, one of which is called
something like auton_mode. If you copy that part of the new default
code to your own default code, I expect you will be able to use that
code in your robot without difficulty.
If auton_mode = 0 then UseControls:
I would like some extra help with this DBryan
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
